Configuring ORR in IOS XRv
j.restaino
I am trying to configuring ORR in IOS XRv according the documentation in https://www.cisco.com/c/en/us/td/docs/routers/virtual-routers/configuration/guide/b-xrv9k-cg/b-xrv9k-cg_chapter_0110.html. I have a test network ensambled with IOS XRv 9000 Version 6.2.25, but i have problems when i try to replicate the configuration that is in the documentation optimal-route-reflection g1 192.0.2.2.
I have not the option to place the IP Address of the RR
RP/0/RP0/CPU0:ASR-UY1(config-bgp-nbr-af)#optimal-route-reflection group1 ?
  <cr>
Despite of that i try to configure, but the configuration fail
RP/0/RP0/CPU0:ASR-1(config-bgp-nbr-af)#sho config
Fri Mar  2 19:31:10.023 UTC
Building configuration...
!! IOS XR Configuration version = 6.2.25
router bgp 65000
 neighbor 1.4.3.1
  address-family vpnv4 unicast
end
RP/0/RP0/CPU0:ASR-1(config-bgp-nbr-af)#commit
Fri Mar  2 19:31:07.364 UTC
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed [inheritance]' from this session to view the errors
RP/0/RP0/CPU0:ASR-1(config-bgp-nbr-af)#sho confi fail
Fri Mar  2 19:31:13.068 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
router bgp 65000
 neighbor 1.4.3.1
!!% 'BGP' detected the 'warning' condition 'Invalid arguments'
end
If anyone can help me, i will be very grateful.
José
3 Accepted Solutions
No Problem..
we have a good document on this by Luc, however i am not sure how to make it externally accessible.
https://techzone.cisco.com/t5/XR-Platform-Independent-Topics/Border-Gateway-Protocol-BGP-Optimal-Route-Reflection/ta-p/901677
Need to check on this
i made a mistake in my earlier post.
it seems vpnv4 is not supported for ORR
from an internal note we see the following
BGP ORR is supported for IPv4 Unicast and IPv6 Unicast
not supported for IPv4 Labelled unicast (VPNv4)
not supported for IPv6 Labelled unicast (VPNv6)
not supported for  VPNv4 and VPNv6 support
11 Replies 11
tkarnani
Hi Jose,
this is a new feature to me, can we check if the optimal-route-reflection group is under the bgp address family? if possible can you provide your bgp config? i can try in our lab
router bgp 9730
 address-family ipv4 unicast
  optimal-route-reflection group1 1.1.1.1
 neighbor 2.2.2.2
  remote-as 100
end
Thanks for your response, i try with a new clean config that i attach below and i have the same problem.
RP/0/RP0/CPU0:ASR-UY1#sho runn router bgp
Thu Mar 8 16:40:57.037 UTC
router bgp 65000
address-family vpnv6 unicast
neighbor-group RR
remote-as 65000
update-source Loopback0
neighbor 10.4.3.1
use neighbor-group RR
neighbor 10.4.4.1
vrf Internet
rd 65000:65000
bgp bestpath as-path multipath-relax
redistribute connected
When i try to config below the address family without a neighbor or a neighbor-group i don't have this option.
RP/0/RP0/CPU0:ASR-UY1(config)#router bgp 65000
RP/0/RP0/CPU0:ASR-UY1(config-bgp)# address-family vpnv4 unicast
RP/0/RP0/CPU0:ASR-UY1(config-bgp-af)#opt?
% Invalid input detected at '^' marker.
And when i want to configure under the address-family but below a neighbor-group i do not have the option to add the RR IP, and when i try to commit without this option i have the problem that the commit fails with an error
RP/0/RP0/CPU0:ASR-UY1(config-bgp-vrf-af)# neighbor-group ANTEL_RR
RP/0/RP0/CPU0:ASR-UY1(config-bgp-nbrgrp)#  address-family vpnv4 unicast
RP/0/RP0/CPU0:ASR-UY1(config-bgp-nbrgrp-af)#optimal-route-reflection ?
  WORD  ORR group name - maximum 32 characters
RP/0/RP0/CPU0:ASR-UY1(config-bgp-nbrgrp-af)#optimal-route-reflection group1 ?
  <cr>
RP/0/RP0/CPU0:ASR-UY1(config-bgp-nbrgrp-af)#commit
Thu Mar  8 16:10:29.524 UTC
RP/0/RP0/CPU0:ASR-UY1(config-bgp-nbrgrp-af)#sho confi fail
Thu Mar  8 16:10:33.028 UTC
!! found below.
router bgp 65000
end
Thanks for your time
José
from reading configuration examples can we try this?
router bgp 6500
Thanks, i could paste this configuration. To be honest is a little bit confuse for me, to configure the feature in address-family ipv4, to be enable to configure the address-family vpnv4.
I will try continue the deploy in my network and test this feature more deeply.
router bgp 65000
 neighbor-group RR
  remote-as 65000
 neighbor 10.4.3.1
 neighbor 10.4.4.1
José
No Problem..
Thanks a for your time again.
José
Thanks ...
To be honest i recently have time to test in deep in my development enviroment, and i can make that the ORR works with VPNv4.
I follow the steps that the document https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/212881-border-gateway-protocol-bgp-optimal-ro.html and i add the configuration necesary to test vpnv4.
The configuration in my vRR is
router bgp 65000
  optimal-route-reflection ppp 1.4.1.1
 neighbor-group PE
  remote-as 65000
   route-reflector-client
 neighbor 1.4.1.1
  use neighbor-group PE
router isis backbone_Int
 net 49.0001.0010.0400.3001.00
 distribute link-state
  metric-style wide
  maximum-paths 32
 interface Loopback0
   metric 1
 interface GigabitEthernet0/0/0/0
  point-to-point
   metric 15
 interface GigabitEthernet0/0/0/1
  point-to-point
   metric 15
And when i try to see if in the neighbor is applied this feature i can not see this.
RP/0/RP0/CPU0:RR-01#sho bgp neighbor 1.4.1.1
Wed Aug  8 15:58:45.109 UTC
BGP neighbor is 1.4.1.1
 Remote AS 65000, local AS 65000, internal link
 Description: ASR-EU1
 Remote router ID 1.4.1.1
 Cluster ID 1.4.3.1
  BGP state = Established, up for 01:44:43
 For Address Family: IPv4 Unicast
  BGP neighbor version 0
  Update group: 0.3 Filter-group: 0.0  No Refresh request being processed
  Route-Reflector Client
  ORR root (configured): ppp; Index: 0
    Extended Nexthop Encoding: advertised
  Route refresh request: received 0, sent 0
 For Address Family: VPNv4 Unicast
  BGP neighbor version 11
  Update group: 0.1 Filter-group: 0.1  No Refresh request being processed
  Route refresh request: received 0, sent 1
I will be very gratefull if you can help me.
Regards.
José
Thanks, you know if this feature is in the roadmap for VPNv4 and VPNv6?
José
