10-06-2015 10:46 AM
I do not understand why the router will not allow me to add this configuration:
configure terminal
do terminal monitor
control-plane
management-plane
inband
interface all
allow SNMP peer
address ipv4 1.2.3.4
allow SSH peer
out-of-band
vrf OOB-MGMT
interface all
allow SSH peer
root
"!!% 'MPP Server Process' detected the 'fatal' condition 'Interface configured/used in other band'"
To me this does not make logical sense - why was this built this way?
Is there any way around it without specifying EVERY interface individually in both the inband and out-of-band configuration?
Solved! Go to Solution.
10-07-2015 02:04 AM
Can you try this as workaround:
group Inband control-plane management-plane inband interface 'TenGigE*' allow TFTP ! interface 'GigabitEthernet*' allow TFTP ! ! ! ! end-group ! control-plane management-plane inband apply-group Inband ! out-of-band interface MgmtEth0/RSP0/CPU0/0 allow SSH allow TFTP ! ! ! !
10-06-2015 12:27 PM
hi Evan,
effectively the only out-of-band interfaces are the MgmtEth on the R(S)P. I don't think that anyone is using any other interface as out-of-band. So in the out-of-band config section you only need to configure the MgmtEth, while you can use "interface all" in the inband section.
Aleksandar
10-06-2015 12:48 PM
This is what I thought too but consider the following ASR config:
control-plane
management-plane
inband
interface all
allow SNMP peer
address ipv4 1.1.1.1
out-of-band
vrf OOB-MGMT
allow SSH peer
address ipv4 2.2.2.2
address ipv4 3.3.3.3
address ipv4 4.4.4.4
I try to update this using adding
configure terminal
control-plane
management-plane
inband
interface all
allow SSH peer
address ipv4 5.5.5.5
The router will not accept this. I just want to add these IP's so I can access the ASR via loopback as well as OOB as OOB will be going away.
control-plane
management-plane
inband
interface all
allow SSH peer
end
10-07-2015 02:04 AM
10-08-2015 07:02 AM
Aleksandar Vidakovic this is a good workaround to keep the configuration clean and after testing it worked for me and so I thank you and I have marked this answer correct. Cheers.
10-08-2015 07:38 AM
I'm happy to hear you found the workaround feasible. Thanks for sharing the feedback!!
10-16-2015 01:11 PM
Aleksandar I am afraid I am still fighting with this
I have a baseconfig that is working well on 90% of my routers. However with a few, there is trouble: (This is an ASR 9001)
control-plane
management-plane
inband
interface Loopback0
allow SSH peer
address ipv4 <address_1>
address ipv4 <address_2>
allow SNMP peer
interface TenGigE0/0/2/0
allow SSH peer
allow SNMP peer
interface TenGigE0/0/2/1
allow SSH peer
allow SNMP peer
interface TenGigE0/0/2/2
allow TFTP
out-of-band
vrf OOB-MGMT
allow all
When I try to add the new configuration using the group, I am unable to poll the loopback IP address or SSH to it:
configure terminal
do terminal monitor
group inband
control-plane
management-plane
inband
allow SSH peer
allow SNMP peer
address ipv4 <address_3>
end-group
control-plane
management-plane
inband
no interface all
no interface Loopback0
no interface TenGigE0/0/2/0
no interface TenGigE0/0/2/1
no interface TenGigE0/0/2/2
no interface TenGigE0/0/2/3
apply-group inband
out-of-band
vrf OOB-MGMT
no allow all
allow SSH peer address ipv4 <address_1>
allow SSH peer address ipv4 <address_2>
root
Note that when I leave the "allow all" under the OOB control-plane configuration, I can still SSH to the loopback.
This almost feels like a bug. SSH/SNMP to Loopback should not depend on configuration of the OOB control-plane.
10-17-2015 04:56 PM
Hi Evan,
the model of the asr9k doesn't matter, from SW forwarding architecture point they are all identical. What matters is the base XR release and SMUs/SPs that are installed. Are they the same on the working and non-working routers?
To understand what was programmed in LPTS based on the control-plane config, please check the
sh lpts pifib brief sh lpts pifib hardware police location <location>
That should help confirm whether the programming matches what you expected based on the config.
/Aleksandar
10-19-2015 07:28 AM
10-19-2015 04:20 PM
hi Evan,
please compare the two output sets before and after the config change:
That should help understand the behaviour.
Aleksandar
10-07-2015 09:32 PM
You can configure a interface as either inband OR outband , under inband you are doing "interface all "which includes mgmtEth 0/RSP0/CPU0/0. So while configuring under outband its failing.
Ehsan
10-08-2015 07:01 AM
Yes, this confirms my suspicions - I was under the impression that "interface all" would not include mgmtEth as they are essentially out of band interfaces. It is unfortunate this was designed this way as it makes the configuration more difficult to maintain and keep "clean," but it is as it is and I appreciate you pointing this out.
10-06-2015 12:48 PM
