converting ipsec configuration from ios to iosxr
claudiols
we have a working ipsec configuration on ios
crypto keyring KRING
  pre-shared-key hostname  BA2211RA1.ba.caixa key SeCretBA2211RA1
  pre-shared-key hostname  BA3618RA1.ba.caixa key SeCretBA3618RA1
crypto isakmp policy  1
encr 3des
authentication  pre-share
group 2
lifetime 3600
crypto isakmp profile  ISAPROF
   keyring KRING
   self-identity  fqdn
   match identity host domain  ba.caixa
   match identity host domain  se.caixa
   local-address  10.144.0.15
crypto ipsec transform-set  VPN esp-3des esp-sha-hmac
crypto dynamic-map DYNMAP  10
set transform-set VPN
set isakmp-profile  ISAPROF
crypto map VPN_AG_EBT  local-address Loopback21
crypto map VPN_AG_EBT 10  ipsec-isakmp dynamic DYNMAP
interface  Port-channel1.521
Will the IOSXR configuration be like this?
pre-shared-key hostname  <Nome unidade Remota> key <Senha>
encryption 3des
group  2
lifetime 3600
   keyring KRING
   self-identity  fqdn
   match identity host domain  <domino CAIXA>
crypto ipsec transform-set  VPN  transform esp-3des esp-sha-hmac
crypto ipsec profile  VPN_AG_EBT
set type dynamic
set pfs group2
interface X/Y
crypto ipsec  VPN_AG_EBT
the thing is, part of the crypto config like keychains are supported as they are used in some auth methods for routing protocols.
true ipsec is not on the 9k, the current ucode has no room for that. next gen might have it and we're also working on a blade or adapter that can assist with this.
I am trying to find an official statement that ipsec on the 9k is not supported, but the more I google it, the more embarassed I get as many things "suggest" that this should work. I am working on rectifying that to remove the ambiguity.
I am also checking in with the CRS and XR12K guys what their support is for ipsec in hw.
Will report back when I have news.
regards
xander
11 Replies 11
Hi Claudiols,
you would need to check the tunnel-ipsec configuration guidelines
crypto ipsec transform-set test1
transform esp-sha-hmac
crypto ipsec profile ipsec_profile1
match transform-set test1
set pfs group2
set type static
interface tunnel-ipsec 1
tunnel source
tunnel destination
crypto isakmp
encryption 3des
lifetime 86400
crypto keyring key1 vrf default
pre-shared-key address IP1 255.255.255.255 key
crypto isakmp profile isakmp_prof
keyring key1
match identity address IP1/32 vrf default
  set interface tunnel-interface1
Foe Further info, you may refer to
http://www.cisco.com/en/US/docs/routers/xr12000/software/xr12k_r4.2/security/configuration/guide/b_syssec_cg42xr12k.html
HTH,
Michel.
I wanted to ask for which XR platform are you asking this about?
Because for instance the ASR9000 doesnt support ipsec encryption yet.
xander
Alexander, thanks, but there is a lot of documentation about ipsec on XR (like http://www.cisco.com/en/US/docs/routers/asr9000/software/security/command/reference/srasr9kipsc.html)
Xander,
Been 3 years and maybe something has improved?
I am using ASR9010, v5.3.3 and can't implement IPsec to work which might be because you state there is no ipsec support.  I get this far:
crypto isakmp keyring VPN-IPsec-GRE
 pre-shared-key address 21.152.56.92 255.255.255.255 key encrypted 04341E1414245252
!  Not to worry - encrypted pw has been modified
crypto isakmp policy 10
 group 2
 encryption 3des
crypto ipsec transform-set Via-GRE esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec profile teRemote
 set pfs group2
 set transform-set Via-GRE
Even the "show" commands seem to work:
RP/0/RSP0/CPU0:petach-tikva-gp# show crypto isakmp keyring
Sun Nov  6 08:45:08.139 IST
IKEv1 KeyRing  VPN-IPsec-GRE
  Vrf : default(VRF-ID: 1610612736)
  Local Address :
    21.152.56.92 Vrf: default(VRF-ID: 1610612736)
    Pre Shared Keys are:
     ip-address  21.152.56.92/32
       key :    xxxxxxx
RP/0/RSP0/CPU0:petach-tikva-gp#show crypto isakmp policy
Sun Nov  6 08:45:49.890 IST
 Global IKE policy
 Protection suite of priority  10
         encryption algorithm:                                                  3DES - 192 bit keys
         hash algorithm:           Secure Hash Standard
         authentication method:    Pre-Shared Key
         Diffie-Hellman group:     #2
         lifetime:                 86400 seconds, no volume limit
 Protection suite of priority  65508
         encryption algorithm:                                                  AES(CBC) - 128 bit keys
         Diffie-Hellman group:     #1
 Protection suite of priority  65510
         hash algorithm:           Message Digest 5
But when I try to add "match" to the profile:
RP/0/RSP0/CPU0:petach-tikva-gp(config)#crypto ipsec profile teRemote
RP/0/RSP0/CPU0:petach-tikva-gp(config-teRemote)#set pfs group2
RP/0/RSP0/CPU0:petach-tikva-gp(config-teRemote)#match ?
  WORD  ACL name
RP/0/RSP0/CPU0:petach-tikva-gp(config-teRemote)#match 100 ?
  transform-set  Specify list of transform sets in priority order
RP/0/RSP0/CPU0:petach-tikva-gp(config-teRemote)#match 100 transform-set Via-GRE
Uncommitted changes found, commit them before exiting(yes/no/cancel)? [cancel]:yes
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed [inheritance]' from this session to view the errors
and "show config failed" shows no commands failed.
Also I tried defining an "ipsec" tunnel and only got this far:
interface tunnel-ipsec10
There appear to be no sub-interface commands for "tunnel-ipsec10".
It is as if ipsec has only been partially ported to IOS-XR and gives one an impression as if it should work, but it really doesn't.
Is it still true that ipsec still doesn't work on ASR9000s w/ IOS-XR?
Hank
xthuijs
hi hank,
correct there is no ipsec support, the only thing that has "changed" is the documentation has been updated and the parser/commit throws you an error now.
we do have some ipsec support via the VSM, but that is not officially publized, the best alternate approach for ipsec is using MACSEC that is accellerated in hardware for the tomahawk linecard.
cheers!
xander
Michel, thanks, do you have any documentation about differences between IPSEC on IOS and IOSXR? Do you have any documentation about GETVPN on IOSXR, for example?
Claudio, indeed very misleading. I have asked the documentation team to remove that over and over, I just asked again for that.
It gives the incorrect impression that a9k does ipsec, the only crypto it does today is for ssh.
Note that at some point we will get a service card/mpa that will assist in the crypto but for now this is not
applicable.
apologies for the confusion.
regards
xander
Thanks Alexander, the customer is trying to configure ipsec on ASR9010 running IOSXR (it is for a service provider, with vrf, BGP,etc); it is already working with IOS on another equipment; What is strange is that the IOSXR have the commands (we did not typed the commit).
Is there any Cisco document with this information that IOSXR do not support ipsec, because in the release notes from 4.2.1 there is a reference about the support for ipsec, is the  ASR9K one exception (Does it run on CRS and 12K)?
regards
xander
Alexander, thanks a lot for your help, but in the link http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/general/release/notes/reln_a9k_421.html we can read that there is support for ipsec on ASR9K-px and do not have on ASR9K-p; is that correct or both ASR9K p and px do not have ipsec support?
the P vs PX defines the RSP type (merged in XR43 btw). the RSP doesnt do the forwarding, it is determined by the LC type. So regardless of P/PX, IPSEC wont work on the existing linecards today.
Havent heard back yet from my gsr and crs guy...
xander
