Diagnosing CRC Errors/Link Flaps
Lyphiard
I'm facing a peculiar error where a TenGigE interface begins rapidly flapping continuously until it is shut/no-shut through the command line. This particular interface is part of a 2-port LAG doing MC-LAG with a set of Juniper switches.
RP/0/RSP0/CPU0:CR01.DAL#show interfaces te0/1/0/0
Thu Nov 22 12:14:10.723 EST
TenGigE0/1/0/0 is down, line protocol is down
  Interface state transitions: 478718
  Hardware is TenGigE, address is d867.d950.59a8 (bia d867.d950.59a8)
  Layer 1 Transport Mode is LAN
  Internet address is Unknown
  MTU 1514 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 10000Mb/s, SR, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  Last link flapped 00:00:01
  Last input 00:00:01, output 00:00:01
  Last clearing of "show interface" counters 1w2d
  5 minute input rate 3049000 bits/sec, 480 packets/sec
  5 minute output rate 233000 bits/sec, 65 packets/sec
     19515912689 packets input, 17358299220865 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 487822 multicast packets
              12 runts, 0 giants, 0 throttles, 0 parity
     300 input errors, 138 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     19408366444 packets output, 16431138891732 bytes, 0 total output drops
     Output 0 broadcast packets, 841514 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     6865 carrier transitions
The number of carrier transitions and input/CRC errors is rapidly increasing at this point.
LC/0/1/CPU0:Nov 22 12:18:35.627 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:36.674 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:36.676 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:36.691 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:36.691 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:37.683 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:37.684 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:37.714 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:37.714 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:38.691 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:38.692 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:38.736 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:38.736 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:39.699 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:39.700 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:39.718 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:39.718 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:40.707 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:40.708 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:40.741 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:40.741 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:41.765 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:41.767 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:41.804 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:41.804 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:42.774 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:42.775 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:Nov 22 12:18:42.785 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:42.785 : ifmgr[201]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Nov 22 12:18:43.782 : ifmgr[201]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
Is this more likely to be a software issue with the LAG bundle or a L1 issue with the transceiver or fiber itself? At the time this begins happening, there was no contact with either ends of the physical connection. After resetting the interface through a shut/no-shut, the interface can stay working for a long time (about a week since it last happened) before this happens again.
Leo Laohoo
Wow. Look at that link go!
I'd start by swapping out the 10 Gbps modules one by one.
After the modules have been swapped out and the problem still persist, swap out the patch cables.
What is the distance between the two chassis?
Indeed, some fibre/port swapping will help isolating the cause. However, before/after any such step, it would be good to check what kind of errors are reported in the output of "show controllers <interface> all".
Other than some CRC/RX errors, I don't see anything that could indicate a software and/or link failure. Perhaps you could take a look?
https://pastebin.com/sSKCz1G9
Replace the module in RP/0/RSP0/CPU0:CR01.DAL first.
