IOS XR XML conversion
bennettjim
Does anyone know if it is possible to convert/parse the XML output from IOS XR into something that is more easily digestable.  The format that we are seeing is very different than what we are used to and would like to be able to parse the output into a format that is more user friendly. Can the XML be converted into an HTML file?    Any idea how we can accomplish this?
Ivan Krimmel
Level 7
Level 7
Hi Jim,
though I am not aware of such a possibility, I will try to answer your question on best effort approach
First in here, I learned that you can use XML API to request information about configuration as well. So I think with certain programmation skills one could benefit out of this interface.
and also there're XML schema objects for every XR platform available on CCO, which could perhaps accompany the conversion process:
ASR9K
c12K
CRS-1
let me know pease if it is what you were looking for.
Best regards,
Ivan.
