01-31-2020 12:09 AM
Does it need to reboot when activating #L-ASR920-1G-12= license in ##ASR920 route
Solved! Go to Solution.
01-31-2020 02:48 AM
No reboot is required. Once you enter the command for activation, you can verify the license by using 'show license all'
01-31-2020 02:48 AM
02-03-2020 01:36 AM
02-03-2020 04:11 AM
i am glad to hear that my reply helped you. keep posted in the community for any further issue or query :)
