Does the CRS-1 MSC fail?
jiang-hui
HI,ALL
when I telnet the CRS-1,I use show diag sum ,show led,show inv command,does the 0/13/* MSC fail?
I have not seen the machine,is there SIP-800 no SPA card cause the problem?
show diag sum
CARD 0/13/* : Unknown Card Type
PLIM 0/PL13/* : Cisco Carrier Routing System SPA Interface Processor Card (NO MSC)
CARD 0/RP0/* : Cisco CRS Series 16 Slots 6 GB Performance Route Processor
CARD 0/RP1/* : Cisco CRS Series 16 Slots 6 GB Performance Route Processor
show led
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#
0/13/*: Module (host) LED status says: OK
0/13/*: Module (jacket) LED status says: Unknown
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#show inventory location 0/13/CPU0
Wed Jan 14 15:52:43.142 GMT
NAME: "0/13/*", DESCR: "Cisco CRS-1 Series Modular Services Card revision B"
PID: CRS-MSC-B         , VID: V08, SN: SAL1614915K
NAME: "0/PL13/*", DESCR: "Cisco Carrier Routing System SPA Interface Processor Card"
PID: CRS1-SIP-800      , VID: V04, SN: SAD140200WY
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#admin show led
Wed Jan 14 23:33:08.402 GMT
     LOCATION        MESSAGE        MODE      STATUS
         0/0/*       IOS XR        DEFAULT   UNLOCKED
         0/1/*       IOS XR        DEFAULT   UNLOCKED
         0/2/*       IOS XR        DEFAULT   UNLOCKED
         0/3/*       IOS XR        DEFAULT   UNLOCKED
         0/4/*       IOS XR        DEFAULT   UNLOCKED
         0/5/*       IOS XR        DEFAULT   UNLOCKED
         0/6/*       IOS XR        DEFAULT   UNLOCKED
         0/7/*       IOS XR        DEFAULT   UNLOCKED
         0/8/*       IOS XR        DEFAULT   UNLOCKED
         0/9/*       IOS XR        DEFAULT   UNLOCKED
        0/10/*       IOS XR        DEFAULT   UNLOCKED
        0/11/*       IOS XR        DEFAULT   UNLOCKED
        0/12/*       IOS XR        DEFAULT   UNLOCKED
        0/13/*       IOS XR        DEFAULT   UNLOCKED
       0/RP0/*       ACTV RP       DEFAULT   UNLOCKED
       0/RP1/*       STBYRDY       DEFAULT   UNLOCKED
       0/FC0/*       IOS XR        DEFAULT   UNLOCKED
       0/FC1/*       IOS XR        DEFAULT   UNLOCKED
       0/AM0/*        0  13  SP    DEFAULT   UNLOCKED
       0/AM1/*        0  13  SP    DEFAULT   UNLOCKED
       0/SM0/*       IOS XR        DEFAULT   UNLOCKED
       0/SM1/*       IOS XR        DEFAULT   UNLOCKED
       0/SM2/*       IOS XR        DEFAULT   UNLOCKED
       0/SM3/*       IOS XR        DEFAULT   UNLOCKED
       0/SM4/*       IOS XR        DEFAULT   UNLOCKED
       0/SM5/*       IOS XR        DEFAULT   UNLOCKED
       0/SM6/*       IOS XR        DEFAULT   UNLOCKED
       0/SM7/*       IOS XR        DEFAULT   UNLOCKED
jiang-hui
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#show platform
Fri Jan 16 10:21:42.874 GMT
Node          Type              PLIM             State           Config State
0/0/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/0/0         MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/0/1         MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/0/2         MSC-B(SPA)        5X1GE            OK              PWR,NSHUT,MON
0/0/4         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/0/5         MSC-B(SPA)        2XOC48-POS       OK              PWR,NSHUT,MON
0/1/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/1/0         MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/1/1         MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/1/2         MSC-B(SPA)        5X1GE            OK              PWR,NSHUT,MON
0/1/4         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/1/5         MSC-B(SPA)        2XOC48-POS       OK              PWR,NSHUT,MON
0/2/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/2/0         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/2/1         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/2/4         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/2/5         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/3/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/3/0         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/3/1         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/3/4         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/3/5         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/4/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/4/0         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/4/1         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/4/4         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/5/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/5/0         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/5/1         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/5/2         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/5/3         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/5/4         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/5/5         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/6/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/6/0         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/6/1         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/6/2         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/6/3         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/6/4         MSC-B(SPA)        8X1GE            OK              PWR,NSHUT,MON
0/6/5         MSC-B(SPA)        5X1GE            OK              PWR,NSHUT,MON
0/7/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/7/0         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/7/1         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/7/4         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/7/5         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/8/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/8/0         MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/8/1         MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/8/4         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/8/5         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/9/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/9/0         MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/9/1         MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/9/4         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/9/5         MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/10/CPU0     MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/10/0        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/10/1        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/10/4        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/10/5        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/11/CPU0     MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/11/0        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/11/1        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/11/4        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/11/5        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/12/CPU0     MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/12/0        MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/12/1        MSC-B(SPA)        OC192RPR-XFP     OK              PWR,NSHUT,MON
0/12/4        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/12/5        MSC-B(SPA)        1x10GE           OK              PWR,NSHUT,MON
0/13/CPU0     MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/RP0/CPU0    RP(Active)        N/A              IOS XR RUN      PWR,NSHUT,MON
0/RP1/CPU0    RP(Standby)       N/A              IOS XR RUN      PWR,NSHUT,MON
I have quite same this problem but I met with CRS-1 Fabric Card.
Symptom:
  • Admin show environment led status says: Unknown
  • Admin show plat state normal
  • Show diagnostic CARD: Unknown Card Type
  • No log relate to the card
  • Show invent normal
Resolution:
                Re-enable power of the card which have a problem.
