ASR9K Failed FPD upgrade
mkhalil10
Hi all
I am facing the below issue
RP/0/RSP1/CPU0:ios#admin upgrade hw-module fpd cbc force location 0/1/CPU0 Tue Mar 22 23:15:14.021 UTC
   CBC UPGRADE TAKES APPROX. 3 - 5 MINUTES TO COMPLETE
   AFTER THE IMAGE IS WRITTEN, THE CBC IS RESET AUTOMATICALLY TO
   ACTIVATE THE NEW IMAGE. NO ACTION IS REQUIRED TO ACTIVATE THE NEW
   CBC IMAGE. PROGRESS STATUS WILL BE PRINTED APPROX. ONCE EVERY 60 SECONDS.
Continue? [confirm]
FPD upgrade started.
FPD upgrade in progress on some hardware, reload/configuration change on those is not recommended as it might cause HW programming failure and result in RMA of the hardware.
Starting the upgrade/download of following FPD:
                                   Current    Upg/Dng
Location    Type Subtype Upg/Dng   Version    Version
0/1/CPU0    lc   cbc     upg        33.2        33.5
FPD upgrade sent to location node0_1_CPU0
FPD upgrade completed for location node0_1_CPU0 % Failed to upgrade 1 FPD for A9K-VSM-500 on location 0/1/CPU0
FPD upgrade has ended.
20 Replies 20
Aleksandar Vidakovic
Which IOS XR release is running on the router?
Can you also share the output of "show canbus server-stats location 0/1/CPU0"?
regards,
Aleksandar
Hi Aleksandar
I reloaded the module and it worked
Anyway , what SMUs are really needed to be applied ? or it's version related ?
BR,
Mohammad
hi Mohammad,
SMUs are specific a SW release. For example if we wanted to deliver a SMU for bug CSCxx0000 on 5.3.2 and 5.3.3, we would have to deliver one SMU for 5.3.2 and one for 5.3.3.
If you would like to avoid the hassle of reviewing individual SMUs, you may want to go for Service Packs instead.
I would also recommend to target an Extended Maintenance Release for deployment.
if you want to simplify the task of orchestrating SW update (SP, SMU or new release packages), you can use the CSM Server to help with that.
I'm sharing some URLs you may find relevant.
  • Service Pack Overview:
    • http://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-xr-software/117550-technote-product-00.html
  • Guidelines for Cisco IOS XR Software (i.e. Extended Maintenance Release bulletin):
    • http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8803/ps5845/product_bulletin_c25-478699.html
  • SMU overview:
    • http://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-xr-software/116332-maintain-ios-xr-smu-00.html
  • CSM Server:
    • https://supportforums.cisco.com/document/12747091/cisco-software-manager-v32-now-cco
regards,
Aleksandar
Hi Aleksandar
I have reloaded the module (through command like) and FPD is upgraded to 33.5
Strange maybe ? :)
BR,
Mohammad
LC reload should be triggered automatically when upgrading FPD (in the future not all FPD upgrades will require a reload). It seems that in this case the automated reset of the board has failed, but the FPD was upgraded. In summary, this is not really an expected behaviour. If the "admin show hw-module fpd" shows that all version are up to date, the VSM should be fine now.
regards,
/Aleksandar
Thanks Aleksandar
Did u face some issues when deploying VSM ?
I am facing a lot of drops in the show cgn nat44 nat1 statistics
BR,
Mohammad
hi Mohammad,
I believe you are already discussing this with Nitin in another thread. If this is a separate issue, please let me know.
regards,
Aleksandar
Dear Aleksandar
Is there a problem if I upgrade a box from 4.3.2 to 5.3.3 directly ? or will there be any restrictions?
hi Mohammad,
you will find a document that explains migration procedure from various releases to 5.3.3:
http://www.cisco.com/web/Cisco_IOS_XR_Software/index.html
regards,
Aleksandar
RP/0/RSP1/CPU0:UM-HQ1-CGN-3G-NAT1#admin install activate disk0:*5.3.3* synch
Sun Oct 11 12:41:02.036 AST
Install operation 136 '(admin) install activate disk0:*5.3.3* synchronous'
started by user 'umc' via CLI at 12:41:02 AST Sun Oct 11 2015.
Info:     This operation will activate the following package:
Info:         disk0:asr9k-mini-px-5.3.3
Error:    Cannot proceed with the activation because of the following package
Error:    incompatibilities:
Error:      asr9k-k9sec-supp-4.3.2 needs iosxr-fwding-4.3.2, or equivalent, to
Error:    be active on the same nodes.
Error:      asr9k-k9sec-supp-4.3.2 needs iosxr-infra-4.3.2, or equivalent, to
Error:      asr9k-k9sec-supp-4.3.2 needs iosxr-os-4.3.2, or equivalent, to be
Error:    active on the same nodes.
Have you added the 5.3.3 k9sec pie to the installation?
Hi Aleksandar
I just added the mini package , should I also include the k9sec package ?
hi Mohammad,
you have two options:
1) if you don't need k9, deactivate the k9 package in 4.3.2 before activating 5.3.3
2) add the 5.3.3 k9 package to the installation
All active packages must be of the same release.
regards,
/Aleksandar
I have removed all packages except for the mini package , then I managed to activate my new software (5.3.3)
BR,
Mohammad
