02-10-2012 04:40 AM
Hello All,
Traffic tagged with outer vlan 3050 and inner vlan 350 isn't matching the following L3 interface configuration:
interface GigabitEthernet0/4/0/28.3050
vrf ABC
ipv4 address 20.0.0.11 255.255.255.0
encapsulation dot1q 3050
Even with no second tag configured should´t the outer vlan match vlan 3050 configured on the interface ?
Many thanks for your help!
David
Solved! Go to Solution.
02-10-2012 08:01 AM
Hello David,
Unambiguous vlan definition works for L2 interfaces.
For L3 you should define 2nd tag too.
vrf ABC
encapsulation dot1q 3050 second-dot1q 350
/A
02-10-2012 08:01 AM
Hello David,
vrf ABC
/A
02-10-2012 08:41 AM
Thanks Akiritch, once again for your prompt response.
