Double tagged traffic on L3 Interface
dfranjoso
Hello All,
Traffic tagged with outer vlan 3050 and inner vlan 350 isn't matching the following L3 interface configuration:
interface GigabitEthernet0/4/0/28.3050
vrf ABC
ipv4 address 20.0.0.11 255.255.255.0
encapsulation dot1q 3050
Even with no second tag configured should´t the outer vlan match vlan 3050 configured on the interface ?
Many thanks for your help!
David
Alexei Kiritchenko
Hello David,
Unambiguous vlan definition works for L2 interfaces.
For L3 you should define 2nd tag too.
vrf ABC
encapsulation dot1q 3050 second-dot1q 350
/A
Alexei Kiritchenko
Hello David,
vrf ABC
/A
Thanks Akiritch, once again for your prompt response.
