enable SFP transmit light on a NCS-5501-SE
matt78907890
Hello, i've got a port that is admin-down and i want to install an optic and enable transmit light. I've tried the commands below and i've got no light on the SFP.
#config
(config)#controller optics 0/0/0/0
(config-Optics)#shut
(config-Optics)#dwdm-carrier 50GHz-grid frequency 19250
(config-Optics)#commit
(config-Optics)#no shutdown
(config-Optics)#end
balaji.bandi
Thanks for your response BB. The other side is connected to a light meter to check for continuity on the fiber.
I figured it out, once i set the speed, the optic turned on. Thanks for you help!
Sure yes because of the variables can be used as below :  (Glad you able to resolve the issue we mark as resolved now)
port-mode speed
To configure the port mode, use the port-mode speed command in optics controller configuration mode.
port-mode speed { 100G | 150G | 200G } mod { 16qam | 8qam |qpsk } fec { 15sdfec | 15sdfecde | 25sdfec | otu7staircase } diff { enable | disable }
BB
