I have the scenario in the figure of the .pptx file attached.
I want to setup two pseudowires to transport Eth. tagged frames between CEs. I have an XR 12k platform with IOS XR 4.2.3. Here are the relevant configurations I made:
PE2-3
interface GigabitEthernet0/4/0/1
cdp
interface GigabitEthernet0/4/0/1.21 l2transport
dot1q vlan 21
interface GigabitEthernet0/4/0/1.22 l2transport
dot1q vlan 22
l2vpn
pw-class A21
encapsulation mpls
transport-mode vlan
tag-rewrite ingress vlan 21
pw-class A22
encapsulation mpls
transport-mode vlan
tag-rewrite ingress vlan 22
xconnect group PROVA
p2p VLAN21
neighbor 192.168.0.13 pw-id 11
pw-class A21
p2p VLAN12
neighbor 192.168.0.13 pw-id 12
pw-class A22
PE1-3
interface GigabitEthernet0/1/0/1
cdp
interface GigabitEthernet0/1/0/1.11 l2transport
dot1q vlan 11
interface GigabitEthernet0/1/0/1.12 l2transport
dot1q vlan 12
l2vpn
pw-class A11
encapsulation mpls
transport-mode vlan
tag-rewrite ingress vlan 11
pw-class A12
encapsulation mpls
transport-mode vlan
tag-rewrite ingress vlan 12
p2p VLAN11
neighbor 192.168.0.23 pw-id 11
pw-class A11
p2p VLAN12
neighbor 192.168.0.23 pw-id 12
pw-class A12
RP/0/0/CPU0:PE1-3#sh l2vpn xconnect
Tue Mar 26 15:57:31.945 UTC
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
SB = Standby, SR = Standby Ready, (PP) = Partially Programmed
XConnect Segment 1 Segment 2
Group Name ST Description ST Description ST
PROVA VLAN11 UP Gi0/1/0/1.11 UP 192.168.0.23 11 UP
PROVA VLAN12 UP Gi0/1/0/1.12 UP 192.168.0.23 12 UP
As you can see from the "show" above, pseudowires stay up. Unfortunately ping from CEx to CEy do not work. For instance, if on CE1-1 I execute "ping 10.1.13.1", the ping does not work. What I found out is that the first Ethernet frame, which is an ARP request, arrives at PE2-3, but does not keep on going to CE2-1. Surely there is a problem with VLAN tags.
Does anybody have an idea on how to let things work ? The same setup with routers using IOS works fine.
Thanks a lot in advance.
Tiziano
