input hold queue value on IOS XR
arulgobi1
how we can check the input hold queue length and current input queue buffers on IOS XR ?
Thanks & Regards,
Gobinath
mdebraba
Hi Gobinath,
Input queue and interface buffers are a software-based router concepts.  All IOS-XR platforms have a distributed HW-forwarding based architecture so those structures don't really apply here.  Problems like buffer leak and input queue wedged are practically unseen in IOS-XR thanks to other protection mechanisms (built in policers, LPTS, ...).  Which information are you trying to get from thse values ?
mdebraba
Hi Gobinath,
Thanks Maxime,
Actually i wanted to get the queue limitation related to SPD ( BGP /ARP  / IPv6)
I think following command gives the answer but ipv6 related stats are missing , I'm seeing quite a number of IPv6
Neighbor Solicitation messages inboud to CPU on IOS platform.
show lpts pifib hardware police location 0/0/cpu0
Tue Apr  9 12:47:13.626 QAT
                Node 0/0/CPU0:
Burst = 100ms for all flow types
FlowType               Policer Type    Cur. Rate Def. Rate Accepted   Dropped
unconfigured-default   100     Static  500       500       0          0
Fragment               106     Static  1000      1000      2          0
OSPF-mc-known          107     Static  20000     20000     318190     0
OSPF-mc-default        111     Static  5000      5000      1          0
OSPF-uc-known          161     Static  5000      5000      0          0
OSPF-uc-default        162     Static  1000      1000      0          0
ISIS-known             108     Static  20000     20000     0          0
ISIS-default           112     Static  5000      5000      0          0
BFD-known              170     Static  8500      8500      0          0
BFD-default            171     Static  8500      8500      0          0
BFD-MP-known           177     Static  8400      8400      0          0
BFD-MP-0               178     Static  1250      1250      0          0
BFD-BLB-known          183     Static  8400      8400      0          0
BFD-BLB-0              184     Static  1250      1250      0          0
BFD-SP-0               182     Static  512       512       0          0
BGP-known              113     Static  25000     25000     72464      0
BGP-cfg-peer           114     Static  10000     10000     107        0
BGP-default            115     Static  1500      1500      271890     0
PIM-mcast-default      116     Static  23000     23000     0          0
PIM-mcast-known        176     Static  23000     23000     0          0
PIM-ucast              117     Static  10000     10000     0          0
IGMP                   118     Static  3500      3500      0          0
ICMP-local             119     Static  2500      2500      39122      0
ICMP-app               120     Static  2500      2500      1124       0
ICMP-control           164     Static  2500      2500      127522     0
ICMP-default           121     Static  2500      2500      1057       0
ICMP-app-default       120     Static  2500      2500      22         0
LDP-TCP-known          122     Static  25000     25000     0          0
LDP-TCP-cfg-peer       152     Static  10000     10000     0          0
LDP-TCP-default        154     Static  10000     10000     0          0
LDP-UDP                158     Static  2500      2500      534845     0
All-routers            160     Static  10000     10000     0          0
LMP-TCP-known          123     Static  25000     25000     0          0
LMP-TCP-cfg-peer       153     Static  10000     10000     0          0
LMP-TCP-default        155     Static  10000     10000     0          0
LMP-UDP                159     Static  2500      2500      0          0
RSVP-UDP               124     Static  7000      7000      0          0
RSVP-default           125     Static  500       500       0          0
RSVP-known             126     Static  7000      7000      0          0
IKE                    127     Static  1000      1000      0          0
IPSEC-known            129     Static  3000      3000      0          0
IPSEC-default          128     Static  1000      1000      0          0
MSDP-known             130     Static  1000      1000      0          0
MSDP-cfg-peer          131     Static  1000      1000      0          0
MSDP-default           132     Static  1000      1000      0          0
SNMP                   133     Static  2000      2000      558766     0
SSH-known              135     Static  1000      1000      0          0
SSH-default            136     Static  1000      1000      0          0
HTTP-known             137     Static  1000      1000      0          0
HTTP-default           138     Static  1000      1000      0          0
SHTTP-known            139     Static  1000      1000      0          0
IFIB_FT_SHTTP_DEFAULT  140     Static  1000      1000      0          0
TELNET-known           141     Static  1000      1000      0          0
TELNET-default         142     Static  1000      1000      5844       0
CSS-known              143     Static  1000      1000      0          0
CSS-default            144     Static  1000      1000      0          0
RSH-known              145     Static  1000      1000      0          0
RSH-default            146     Static  1000      1000      0          0
UDP-known              147     Static  25000     25000     0          0
UDP-listen             156     Static  4000      4000      0          0
UDP-cfg-peer           157     Static  4000      4000      0          0
UDP-default            101     Static  500       500       2232       0
TCP-known              148     Static  25000     25000     0          0
TCP-listen             149     Static  25000     25000     0          0
TCP-cfg-peer           150     Static  25000     25000     0          0
TCP-default            102     Static  500       500       41112      0
Mcast-known            151     Static  25000     25000     0          0
Mcast-default          103     Static  500       500       0          0
Raw-listen             104     Static  500       500       0          0
Raw-default            105     Static  500       500       0          0
Ip-Sla                 163     Static  10000     10000     0          0
EIGRP                  109     Static  20000     20000     0          0
RIP                    110     Static  20000     20000     0          0
L2TPv3                 165     Static  25000     25000     0          0
PCEP                   166     Static  100       100       0          0
GRE                    167     Static  1000      1000      0          0
VRRP                   168     Static  1000      1000      0          0
HSRP                   169     Static  400       400       0          0
MPLS-oam               172     Static  100       100       0          0
L2TPv2-default         179     Static  700       700       0          0
L2TPv2-known           181     Static  2000      2000      0          0
DNS                    173     Static  500       500       4          0
RADIUS                 174     Static  7000      7000      0          0
TACACS                 175     Static  500       500       0          0
NTP-default            134     Static  500       500       1          0
NTP-known              180     Static  500       500       2480       0
