ERSPAN on NCS 540 XR6.3
Has anybody been able to get ERSPAN running on NCS 540 with XR6.3? I am trying to look at traffic coming in from a TenGig interface and I am getting:
Tue Nov 27 16:42:14.827 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface TenGigE0/0/0/4
monitor-session fiji ethernet direction rx-only
!!% 'SPAN' detected the 'warning' condition 'The platform encountered an error processing a SPAN operation': Operation not supported
end
What is the most likely reason for this, except for that the feature will be available in the next release?
weswang
add port_level in the command, seems work
Running into the same issue. Can you be more specific what this means? What specific commands should I run?
Here is the config guide, it is same for ncs5500 and 540.
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/interfaces/63x/b-interfaces-hardware-component-cg-63x-ncs540/b-interfaces-hardware-component-cg-ncs5500-63x_chapter_01000.html
Like was mentioned prior you need to specify the port-only keyword.
Sam
