Facing ssh: connect to host port 22: Connection refused Issue on Cisco XR
xrohith
I have enabled ssh but still I face this issue when trying to login.
I have generated key using  #crypto key generate rsa usage-keys test.
And after this enabled SSH v2.
But still not able to login.
Here is the output for ##show run | i ssh
Tue Jan 14 09:40:43.714 UTC
Building configuration...
ssh
ssh server rate-limit 600
ssh server v2
ssh server netconf vrf default
Please help me resolve the issue. Not sure what I'm I missing here.
tkarnani
check
show tcp brief | inc 22
make sure port 22 is listening
also check control plane to see that it is allowed via inband or out-of-band
control-plane
management-plane
out-of-band
interface all
allow SSH
Thanks!
decode.chr13
You should also configure.
For OOB (thru MgmtEth0/RSP0/CPU0/0 or 1 ports):
control-plane
management-plane
  out-of-band
   interface MgmtEth0/RSP0/CPU0/0
    allow SSH
For inband (thru your dataplane ports, linke Te 0/0/0/0):
control-plane
management-plane
  inband
   interface TenGigE0/0/0/0
    allow SSH
For both, you can use both subsections (out-of-band and inband)
Please don't forget to generate certificate! Otherwise it won't work. Use this command from exec:
crypto key generate rsa general-keys ssh-keys
