Fast Error Detection in ASR9K
pegasusjwon
Good day, I am wondering to ask one thing.
I am doing some maintenance ASR9K in Asia Region.
Mostly I  troubleshooted a lot of issue after failure occured.
But my client want to know more fastly in critical situation before happened.(Liked rebooted or module stop)
And I found some solution, OBFL.
But I want to ask is there more solution for providing my client?
My client do not want to turn on the debug.
Thank you!
5 Replies 5
Aleksandar Vidakovic
OBFL (on-board failure logging) logs critical information and errors to persistent memory on a line card. This is used for post-mortem analysis, it's not a tool for proactive monitoring.
If you want to proactively monitor the health status of an ASR9k, you can use the methods described in  https://supportforums.cisco.com/document/9881576/asr9000xr-monitoring-cpu-and-memory.
A much more user friendly tool is "Platform Automated Monitoring (PAM)". At present it's supported on 64-bit IOS XR.
Thank you so much! It's so helpful! I will go to deep inside to this document :D
I have an additional question. How can I know 64-bit IOS XR?
64-bit IOS XR is available today as 6.1.2 on CCO. The only supported hardware today are RSP-880 with 8x100G and 12x100G Tomahawk linecards.
Hello Aleksandar,
That was an interesting tool, thank you for sharing.
