Filters on packet lenght on ASR9k 4.2
In the Access List manual of version 4.2
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/addr_serv/command/reference/b_ipaddr_cr42asr9k_chapter_01.html#wp1019212976
I read that there is a possiblity to filter packets according to packet-length. Has anybody been able to use this feature? Is it just for specific protocols? I have tried it in various contexts but have not been successful so far.
Hi Matthias,
Reading through your referenced link I find no mentioning of this feature.
Florian
Bryan Garland
Matthias,
I haven't heard of that capability with regards to straight ACLs.  You can capture so many bytes with regards to SPAN which can be used from an ACL.  It's referred to as partial packet mirroring.  Maybe that is what you are referring to?
RP/0/RP0/CPU0:ASR9922-A(config)#ipv4 access-list blah permit ipv4 any any ?
  capture     Capture matched packet
  default     Use specified default nexthop on match against this entry
  dscp        Match packets with given DSCP value(s)
  fragments   Check non-initial fragments
  log         Log matches against this entry
  log-input   Log matches against this entry, including input interface
  nexthop1    Forward to specified nexthop on match against this entry
  precedence  Match packets with given precedence
  ttl         match against ttl
Info regarding SPAN, use this link:
https://supportforums.cisco.com/docs/DOC-15772
Bryan
