FPD upgrade fail FPD path does not exist
I have a ASR9001 with 6.7.3 when I try and do a FPD upgrade here is what I am getting
rommon_fpd_agent[323]: %PLATFORM-FPD-3-ERR : fpd-err: Unable to unzip the binary file ,the FPD path does not exists : harddisk:
I have the fpd pie installed so my question is there a way to change the path to look at disk0: ?
@DouglasDawson44599
 How did you run the command to start the upgrade. There is "location" option on the command upgrade hw-module fpd
balaji.bandi
what is the commands you used to upgrade ?
Follow below thread : (there is good PDF attached with commands that give you some direction)
https://community.cisco.com/t5/xr-os-and-platforms/xr-upgrade-5-3-1-gt-6-3-3-6-4-2-fails-on-quot-install-add-quot/td-p/3708618
BB
Here is the command I used.  upgrade hw-module fpd rommon location 0/RSP0/CPU0 and I get the above result
If i do a sh fpd package I get the package information.
