Hi All,
I've to plain upgrade currently XR 3.8 to 4.0 version, now i already reading many time of step document on cisco, but i still got many issue in my mine and my Big customer mine as below;
1. I've 4 unit of CRS-1 any run many sevvices (BGP,MPLS,L2VPN,L3VPN,QOS) this services will get downtime or not?
2. We need to upgrade firmware before upgrade IOS-XR or IOS-XR upgrade before firmware or no need firmware upgrade?
3. PCMCIA Flashdisk now we've free 2.0G spac it's enouch or not, if not enouch how we can do it?
4. For additional Packet (MPLS,Diag) we must install after we already updrade to 4.0 or not?
So need anyone helpfull and thanks alot that any help.
Thanks.
KG7.
Hi KG,
1.These service will be impacted becaue router will be reloaded
2.Normally, you may upgrade the firmware after XR upgrade
3.2Gig is enough for 4.0.0 release
4.You may install all packages at once so minimize the downtime.
I would recommend to check the procedure
http://www.cisco.com/web/Cisco_IOS_XR_Software/pdf/CRS-1_Upgrade_Procedure_3_6_x_3_9_x_to_4_0_0.pdf
It is detailed and describing all necessary steps.
wbr
/vz
many thank for for answer;
I'll try to discuss with customer on Friday, How i've some question is
What the different functions between XR_3.9 and 4.0 can we compare two versions that which one is good than one.
Thanks many help Vadim.
KG7
Hi KG7,
There are some new features and you can read about them in Release NOtes
Hope it will help you
wbr
/vz
Hi Vadim,
Thanks again it's so cool, and some anither issue for my plain to upgrade next week could you please final proof that
my flashsystem it's ok, ready to upgrade to XR 4.0 or not, as below;
RP/0/RP0/CPU0:sh filesystem
Mon Sep 10 17:09:43.800 THAI
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - network rw qsm/dev/fs/tftp:
- - network rw qsm/dev/fs/rcp:
- - network rw qsm/dev/fs/ftp:
1043456 995328 dumper-lnk rw qsm/dumper_nvram:
6289231872 6289223680 dumper-lnk rw qsm/dumper_harddiskb:
35706617856 35697866240 dumper-lnk rw qsm/dumper_harddiska:
18003460608 17932029952 dumper-lnk rw qsm/dumper_harddisk:
2102788096 2102657024 dumper-lnk rw qsm/dumper_disk0a:
2102722560 1512538112 dumper-lnk rw qsm/dumper_disk0:
62390272 38527364 dumper-lnk rw qsm/dumper_bootflash:
35706617856 35697866240 harddisk rw harddiska:
18003460608 17932029952 harddisk rw harddisk:
6289231872 6289223680 harddisk rw harddiskb:
2102722560 1512538112 flash-disk rw disk0:
2102788096 2102657024 flash-disk rw disk0a:
1043456 995328 nvram rw nvram:
62390272 38527364 flash rw bootflash:
Have a nice day.
KG7
