How to capture packets in the forwarding path on NCS 540 7.3.2
jhammond75
Have an NCS540 running 7.3.2 and want to capture and examine packet traffic
8 Replies 8
Thank you. I tried that and here's what I got
(config)#monitor-session TEST ethernet
(config-mon)#destination file size 10000
RP/0/RP0/CPU0:N540-1-LG2-A238(config-mon)#exit
RP/0/RP0/CPU0:N540-1-LG2-A238(config)#int Te0/0/0/8
RP/0/RP0/CPU0:N540-1-LG2-A238(config-if)#monitor-session TEST ethernet port-level
RP/0/RP0/CPU0:N540-1-LG2-A238(config-if-mon)#exit
RP/0/RP0/CPU0:N540-1-LG2-A238(config-if)#exit
RP/0/RP0/CPU0:N540-1-LG2-A238(config)#monitor-session TEST ?
destination Specify the destination that traffic should be replicated to
discard-class Specify the discard class value to be set on all traffic mirrored to th
e destination
ethernet Replicate Ethernet traffic
inject-interface Specify the attachment interface into which traffic may be injected fro
m the SPAN session's destination
traffic-class Specify the traffic class value to be set on all traffic mirrored to th
e destination
<cr>
packet-collection start not an option.
I'm sure this is user error
to start the packet collection you need to be in exec-mode not config mode
Hello, could you please let us know if "span to file" should be supported also on NCS540 running XR7?
jhammond75
Thank you. would that be the admin command.
RP/0/RP0/CPU0:N540-1-LG2-A238#monitor-session
% Invalid input detected at '^' marker.
admin is not required
RP/0/RP0/CPU0:NCS-540-A#monitor-session test packet-collection st
start stop
RP/0/RP0/CPU0:NCS-540-A#monitor-session test packet-collection st?
start stop
RP/0/RP0/CPU0:NCS-540-A#monitor-session test packet-collection start ?
<cr>
do you have tacacs enabled that may be blocking this command?
Thank you
Thank you
RP/0/RP0/CPU0:N540-1-LG2-A238#monitor-session test packet-collection start ?
RP/0/RP0/CPU0:N540-1-LG2-A238#show tacacs
Mon Jan 23 17:04:42.508 UTC
RP/0/RP0/CPU0:N540-1-LG2-A238#show tacacs requests
Mon Jan 23 17:06:05.607 UTC
can you check show user group, make sure your account has cisco-support and rootsystem group privileges
thanks
