How to capture packets in the forwarding path on NCS 540
aseem_rai
hi
I am running NCS540 with XR7.1.2 . Is there a way we can capture packets ingress/egress which are in the forwarding path .
Also, is there any way to also capture control plane packets on this to examine them ?
Please suggest.
Aseem.
tkarnani
Hi Aseem, you can run span to file in 7.1.2
this will create a pcap on the disk, you can copy it off the router.
here is a brief guide
Configuration.
monitor-session SPAN ethernet
destination file size 10000000 buffer-type linear
interface Bundle-Ether51
mtu 1540
monitor-session SPAN ethernet direction rx-only
Start capture
monitor-session SPAN packet-collection start
Stop capture and write to file.
monitor-session SPAN packet-collection stop write directory /misc/disk1 filename SPANTEST
copy span file off disk to ftp
dir harddisk:/node0_0_CPU0
copy harddisk:/node0_0_CPU0/SPANTEST.pcap ftp://lab:lab@1.2.3.4
Hello tkarnani,
Actually this is not working for my version of NCS540
RP/0/RP0/CPU0:LHR(config-if-mon)#show configuration failed
Sun Dec 10 02:50:16.213 IST
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface GigabitEthernet0/0/0/6
!!% 'SPAN' detected the 'warning' condition 'The platform encountered an error processing a SPAN operation': Operation not supported
end
Sun Dec 10 02:50:27.484 IST
Building configuration...
!! IOS XR Configuration 7.1.2
end
Hello @aseem_rai ,
You need to add the "port-level" keyword in order for this to work.
monitor-session SPAN ethernet port-level
Hope it resolve your issue.
Have a wonderful day.
Kind Regards,
Antoine
