How to check ASR9k is 32bit or 64bit?
FrankHu114051
What is the command to see my ASR9k is runnung 32 or 64 bit?
2 Accepted Solutions
Yeah x64 in the image name (show install act summ) stands for 64bit. If missing, means 32 bit.
8 Replies 8
Seb Rupik
Hi there,
Not sure there is a platform command, but as a good rule of thumb if an OS has more than 4GB of system memory then it must be a 64bit OS.
cheers,
Seb.
Could you provide an example to show "OS has more than 4GB of system memory" - Thanks a lot!
show system resource
...will tell you how much memory is available on each card.
Yeah...well...that's bull**bleep**! And it's misleading for someone who doesn't know!
There is no rule of thumb that says that and there are a lot of routers that have 8Gb of RAM and they run on 32bits.
"As a rule of thumb" next time try searching the official Cisco documentation.
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/migration/guide/b-migration-to-ios-xr-64-bit/m-difference-32-bit-and-64-bit-os.html
Seb Rupik
This may answer your question more specifically:
https://community.cisco.com/t5/service-providers-documents/ios-xr-release-strategy-and-deployment-recommendation/ta-p/3165422
...check your OS binary file name.
Syed Zaidi
We can check from two easy clis as follows
  • admin show platform
  • admin show version
32BIT output of the clis
RP/0/RSP0/CPU0:ASR9001-A#admin show platform
Sat Sep 28 02:00:44.144 GMT
Node Type State Config State
0/RSP0/CPU0 ASR9001-RP(Active) IOS XR RUN PWR,NSHUT,MON
0/FT0/SP ASR-9001-FAN READY
0/0/CPU0 ASR9001-LC IOS XR RUN PWR,NSHUT,MON
0/0/1 A9K-MPA-20X1GE OK PWR,NSHUT,MON
0/PS0/M0/SP A9K-750W-AC READY PWR,NSHUT,MON
0/PS0/M1/SP UNKNOWN FAILED PWR,NSHUT,MON
RP/0/RSP0/CPU0:ASR9001-A#admin show version
Sat Sep 28 02:00:48.869 GMT
Cisco IOS XR Software, Version 6.5.3[Default]
Copyright (c) 2019 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 2.04(20140227:092320) [ASR9K ROMMON],
ASR9001-A uptime is 1 week, 6 days, 23 hours, 40 minutes
System image file is "bootflash:disk0/asr9k-os-mbi-6.5.3/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (P4040) processor with 8388608K bytes of memory.
P4040 processor at 1500MHz, Revision 2.0
ASR-9001 Chassis
2 Management Ethernet
7 GigabitEthernet/IEEE 802.3 interface(s)
20 GigabitEthernet
4 TenGigE
4 DWDM controller(s)
4 WANPHY controller(s)
219k bytes of non-volatile configuration memory.
2940M bytes of hard disk.
4014064k bytes of disk0: (Sector size 512 bytes).
Configuration register on node 0/RSP0/CPU0 is 0x2102
Boot device on node 0/RSP0/CPU0 is disk0:
Package active on node 0/RSP0/CPU0:
asr9k-fpd, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-fpd-6.5.3
Built on Tue Mar 26 22:38:52 GMT 2019
By iox-ucs-017 in /auto/srcarchive13/prod/6.5.3/asr9k-px/ws for pie
asr9k-fpd-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-fpd-px-6.5.3
Built on Tue Mar 26 22:39:53 GMT 2019
iosxr-security, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-security-6.5.3
Built on Tue Mar 26 22:36:00 GMT 2019
asr9k-k9sec-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-k9sec-supp-6.5.3
asr9k-k9sec-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-k9sec-px-6.5.3
Built on Tue Mar 26 22:36:27 GMT 2019
iosxr-mgbl, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-mgbl-6.5.3
Built on Tue Mar 26 22:38:00 GMT 2019
asr9k-mgbl-supp, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-mgbl-supp-6.5.3
asr9k-mgbl-px, V 6.5.3[Default], Cisco Systems, at disk0:asr9k-mgbl-px-6.5.3
Built on Tue Mar 26 22:38:44 GMT 2019
iosxr-infra, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-infra-6.5.3
Built on Tue Mar 26 23:15:15 GMT 2019
iosxr-fwding, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-fwding-6.5.3
iosxr-routing, V 6.5.3[Default], Cisco Systems, at disk0:iosxr-routing-6.5.3
--More--
64 BIT output of the clis
RP/0/RSP0/CPU0:ASR-9904-eXR#admin show plat
Sat Sep 28 02:18:33.739 HKT
Location Card Type HW State SW State Config State
0/0 A9K-8X100GE-L-SE OPERATIONAL OPERATIONAL NSHUT
0/RSP0 A9K-RSP880-SE OPERATIONAL OPERATIONAL NSHUT
0/RSP1 A9K-RSP880-SE OPERATIONAL OPERATIONAL NSHUT
0/FT0 ASR-9904-FAN OPERATIONAL N/A NSHUT
0/PT0 A9K-AC-PEM-V2 OPERATIONAL N/A NSHUT
RP/0/RSP0/CPU0:ASR-9904-eXR#admin show ver
Sat Sep 28 02:18:39.395 HKT
Cisco IOS XR Admin Software, Version 6.6.2
Copyright (c) 2013-2019 by Cisco Systems, Inc.
Build Information:
Built By : ahoang
Built On : Fri Apr 26 15:06:33 PDT 2019
Build Host : iox-ucs-032
Workspace : /auto/srcarchive16/prod/6.6.2/asr9k-x64/ws
Version : 6.6.2
System uptime is 4 hours, 57 minutes
Elvin Arias
When I am working on an ASR9K, I usually spot wether the platform is 32-bit or 64-bit by executing the "show platform" command.
Outputs will be different.
RP/0/RSP0/CPU0:router:router(admin) # show platform
Wed Jul  3 11:34:18.487 UTC
0/RP0/CPU0      ASR-9922-RP-SE(Active)    IOS XR RUN       PWR,NSHUT,MON <<< State for 32-bit would be IOS XR RUN.
sysadmin-vm:0_RP0#show platform
Location Card Type HW State SW State Config State ---------------------------------------------------------------------------- 0/0 NC55-36X100G OPERATIONAL OPERATIONAL NSHUT <<< State for 64-bit is OPERATIONAL.
Elvin
