ASR903 SSH-3-RSA_SIGN_FAIL
sergei-bilan
Hi team, After switching to a backup RSP board (on ASR903), using the backup forced switching method, it became impossible to connect to the router via the ssh protocol (telnet worked, ping went through, and all protocols functioned). After returning to the main RSP board, the connection was possible again. Added error log. Please help solve problems.
000255: Oct 6 19:38:00: %SSH-3-RSA_SIGN_FAIL: Signature connection failed, status 14
000256: Oct 6 19:38:00: %SSH-3-RSA_SIGN_FAIL: Signature creation failed, status 23
000257: Oct 6 19:38:00: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.1.201.85 (tty = 0) using crypto cipher '', hmac '' Failed
000258: Oct 6 19:38:00: %SSH-5-SSH2_CLOSE: SSH2 Session from 10.1.201.85 (tty = 0) for user '' using crypto cipher '', hmac '' closed
000259: Oct 6 19:38:19: %SSH-3-RSA_SIGN_FAIL: Signature connection failed, status 14
000260: Oct 6 19:38:19: %SSH-3-RSA_SIGN_FAIL: Signature creation failed, status 23
000261: Oct 6 19:38:19: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.1.201.85 (tty = 0) using crypto cipher '', hmac '' Failed
000262: Oct 6 19:38:19: %SSH-5-SSH2_CLOSE: SSH2 Session from 10.1.201.85 (tty = 0) for user '' using crypto cipher '', hmac '' closed
000263: Oct 6 19:38:37: %SSH-3-RSA_SIGN_FAIL: Signature connection failed, status 14
000264: Oct 6 19:38:37: %SSH-3-RSA_SIGN_FAIL: Signature creation failed, status 23
000265: Oct 6 19:38:37: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.1.201.84 (tty = 0) using crypto cipher '', hmac '' Failed
000266: Oct 6 19:38:37: %SSH-5-SSH2_CLOSE: SSH2 Session from 10.1.201.84 (tty = 0) for user '' using crypto cipher '', hmac '' closed
000267: Oct 6 19:39:06: %SSH-3-RSA_SIGN_FAIL: Signature connection failed, status 14
000268: Oct 6 19:39:06: %SSH-3-RSA_SIGN_FAIL: Signature creation failed, status 23
000269: Oct 6 19:39:06: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.1.201.85 (tty = 0) using crypto cipher '', hmac '' Failed
000270: Oct 6 19:39:06: %SSH-5-SSH2_CLOSE: SSH2 Session from 10.1.201.85 (tty = 0) for user '' using crypto cipher '', hmac '' closed
000271: Oct 6 19:42:25.360: NTP Core (INFO): 10.1.201.8 8015 85 restart timeout
000272: Oct 6 19:42:30.360: NTP Core (INFO): 10.1.201.136 8015 85 restart timeout
000273: Oct 6 19:43:21: %IOSXE_OIR-6-ONLINECARD: Card (rp) online in slot R1
000274: Oct 6 19:43:21: %IOSXE_RP_ALARM-6-INFO: cleared MAJOR module R1: Boot state
000275: Oct 6 19:43:30: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
000276: Oct 6 19:43:30: %IOSXE_OIR-6-OFFLINECARD: Card (cc) offline in slot 1
000277: Oct 6 19:43:39: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F1
000278: Oct 6 19:44:20: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby insertion (raw-event=PEER_FOUND(4))
000279: Oct 6 19:44:20: %IOSXE_RP_ALARM-6-INFO: cleared MAJOR module R0: Secondary removed
000280: Oct 6 19:44:20: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby insertion (raw-event=PEER_REDUNDANCY_STATE_CHANGE(5))
000281: Oct 6 19:44:25: %IOSXE_RP_ALARM-6-INFO: cleared CRITICAL module R0: Cutover
000282: Oct 6 19:45:18: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
000283: Oct 6 19:45:50: %IOSXE-3-PLATFORM: R1/0: uea_mgr: QDR 0 is Ready
000284: Oct 6 19:45:50: %IOSXE-3-PLATFORM: R1/0: uea_mgr: QDR 1 is Ready
000285: Oct 6 19:45:55: %LDP-5-GR: LDP restarted gracefully. Removing preserved forwarding state.
000286: Oct 6 19:47:46: %SSH-3-RSA_SIGN_FAIL: Signature connection failed, status 14
000287: Oct 6 19:47:46: %SSH-3-RSA_SIGN_FAIL: Signature creation failed, status 23
000288: Oct 6 19:47:46: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.1.201.85 (tty = 0) using crypto cipher '', hmac '' Failed
000289: Oct 6 19:47:46: %SSH-5-SSH2_CLOSE: SSH2 Session from 10.1.201.85 (tty = 0) for user '' using crypto cipher '', hmac '' closed
000290: Oct 6 19:47:51: %IOSXE-3-PLATFORM: R1/0: uea_mgr: Warning: Max Safe TCAM Limit (1024) reached for Ipv4 Qos in unit 0
000291: Oct 6 19:48:05: %CMRP-6-FP_HA_STATUS: R1/0: cmand: F0 redundancy state is Active with ready Standby
000292: Oct 6 19:48:05: %CMRP-6-FP_HA_STATUS: R0/0: cmand: F0 redundancy state is Active with ready Standby
000293: Oct 6 19:48:08: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
000294: Oct 6 19:48:09: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Hello team!
I'm also interested in this question. Does anyone have any ideas about this situation?
