How to get FAN status and Power supply status via SNMP OID for ASR1001-HX?
d-silwer
I can't find an appropriate oid that provides the value 0 or 1 or 2 for failure, ok or "not present" for power supply or fans. Using IOS XE 16.5.1 on an ASR1001-HX.
Any ideas? Have tried the usual ios oid's and the ASR9k oid's but it not working?
d-silwer
Anyone? Trying to figure out the OID for power supply status and fan status using snmpwalk.
Found it myself in the end...
For power supply PSU0:
enterprises.9.9.91.1.1.1.1.4.5
For power supply PSU1:
enterprises.9.9.91.1.1.1.1.4.25
OK value 1
Not ok value 0
