How to get Multicast Flow Rate via SNMP - ASR9000
I'm wondering if there is a way to get the output of the "sh mfib vrf xxx route rate" using SNMP.I would like to monitor and graph the rate of each (S,G) over time.
Does someone know if there is an OID to get this info?? This is for ASR9000 using XR 5.3.1
Thanks!
Jacobo Schneider
xthuijs
hi jacobo, the actual bps rate from the cli will not be in a mib or added (will be available in yang models), but with mrtg or the like you can take the packet counters and have an offline tool compute the rate. I think the following may help for that:
IOS-XR MIB, for multicast traffic is CISCO-IETF-IPMROUTE-MIB
(ftp://ftp.cisco.com/pub/mibs/v2/CISCO-IETF-IPMROUTE-MIB.my).
In this there are "cIpMRoutePkts", "cIpMRouteDifferentInIfPackets", "cIpMRouteOctets" and "cIpMRouteHCOctets"
xander
