how to register ASR9902 Smart license
ninazhang
We got pair of ASR9902 and wants to register Smart Software Licensing under our default account. I created a new token, but couldn't find the commands that cisco web provided as following from (system-admin) level.  I already enabled smart flexible-consumption. How to i register my two new ASR9902?
license smart flexible-consumption enable
RP/0/RSP1/CPU0:ROA(admin)#license smart register idtoken
RP/0/RP0/CPU0:DC-EXT-ASR9K-3-6-28#license ?
smart Smart Licensing
RP/0/RP0/CPU0:DC-EXT-ASR9K-3-6-28#license smart ?
factory Execute Smart Licensing Factory commands
import Import authcode, policies, trustcode etc
mfg Factory license reservation feature
save save
sync Sync with CSLU/CSSM
trust Establish trust between PI and CSLU/CSSM
RP/0/RP0/CPU0:DC-EXT-ASR9K-3-6-28#sho license sum
Wed Mar 12 09:53:21.294 EDT
Account Information:
Smart Account: <none>
Virtual Account: <none>
License Usage:
License Entitlement Tag Count Status
ADV_100G_RTU_1 (ADV-SE-100G-RTU-1) 1 PENDING
ADV_ED_100G_SIA_3 (ADV-ED-100G-SIA3) 1 PENDING
ASR_9902_TRK (ASR_9902_TRK) 1 PENDING
ESS_100G_RTU_1 (ESS-SE-100G-RTU-1) 2 PENDING
ESS_ED_100G_SIA_3 (ESS-ED-100G-SIA3) 2 PENDING
RP/0/RP0/CPU0:DC-EXT-ASR9K-3-6-28#sho license all
Wed Mar 12 09:53:26.110 EDT
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: True
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not Configured
VRF:
Not Supported
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Jun 09 2025 18:28:29 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Mar 11 2025 18:30:29 UTC
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
Secondary Signing Cert: 0
License Usage
ADV_100G_RTU_1 (ADV-SE-100G-RTU-1):
Description: Advantage Software RTU License (per 100G) for Edge
Count: 1
Version: 1.0
Status: PENDING
Export status: NOT RESTRICTED
Feature Name: ADV_100G_RTU_1
Feature Description: Advantage Software RTU License (per 100G) for Edge
Enforcement type: NOT ENFORCED
License type: Perpetual
ADV_ED_100G_SIA_3 (ADV-ED-100G-SIA3):
Description: Advantage Edge Subscription SIA
Count: 1
Version: 1.0
Status: PENDING
Feature Name: ADV_ED_100G_SIA_3
Feature Description: Advantage Edge Subscription SIA
License type: Subscription
ASR_9902_TRK (ASR_9902_TRK):
Description: 9902 Base Hardware Tracking PID
Count: 1
Version: 1.0
Status: PENDING
Feature Name: ASR_9902_TRK
Feature Description: 9902 Base Hardware Tracking PID
ESS_100G_RTU_1 (ESS-SE-100G-RTU-1):
Description: Essentials Software RTU License (per 100G) for Edge
Count: 2
Version: 1.0
Status: PENDING
Feature Name: ESS_100G_RTU_1
Feature Description: Essentials Software RTU License (per 100G) for Edge
ESS_ED_100G_SIA_3 (ESS-ED-100G-SIA3):
Description: Essentials Edge Subscription SIA
Count: 2
Version: 1.0
Status: PENDING
Feature Name: ESS_ED_100G_SIA_3
Feature Description: Essentials Edge Subscription SIA
Product Information
UDI: PID:ASR-9902,SN:FOC2849Nxxx
Agent Version
Smart Agent for Licensing: 5.9.34/9591040b9
License Authorizations
Overall status:
Active: PID:ASR-9902,SN:FOC2849Nxxx
Status: NOT INSTALLED
Purchased Licenses:
No Purchase Information Available
Enforcement Status:
No Enforcement Status Information Available
Usage Report Summary:
Total: 5, Purged: 0
Total Acknowledged Received: 0, Waiting for Ack: 0
Available to Report: 5 Collecting Data: 5
Device Telemetry Report Summary:
Data Channel: AVAILABLE
Reports on disk: 0
ninazhang
The issue has been solved by using  Offline Deployments Based on your Network Air-gapped deployments.
https://www.cisco.com/c/en/us/td/docs/iosxr/licensing/article/ios-xr-smart-licensing.html#offline-deployment
can you post 'sh run call-home'  and 'show license status'
is your device registered to CSSM (cisco cloud or on prem licensing server) ?
it appears to not be registered from the above outputs
Mark
rbalina
Hi ninazhang,
I have observed the below information provided in the output.
Transport:
Type: cslu
Cslu address: <empty>. <<<<<<<<<
Please attempt to configure the CSLU address and check the status
Refer the below link
https://www.cisco.com/c/en/us/td/docs/iosxr/licensing/article/ios-xr-smart-licensing-using-policy.html
ninazhang
