How to test routing entry performance in ASR 9000 ?
I have tester (ixia). It have 2 port TE, but each port on asr 9000 has limited about 500,000 prefix. What should I do?
best regards
Laurent Aubert
Please explain with more details what you want to achieve because 500k prefixes is the default scale profile so it's expected.
Laurent.
I want to test how many maximum routing table prefixes of asr 9000 follow to cisco document is real ?
But,It tester limited has 2 interface. Now, I connected point-to-point. Tester == ASR 9000
I can't send prefix over 1M (500+500). Do you have any idea to send prefix to follow a cisco document ?
Thanks.
Which Cisco document are you referring to ?
Also 1M is very closed to the maximum the box can support so it seems to me your test is successful :-)
Laurent.
You can use BGP and peer with a machine that runs Quagga. Using scripting to generate them (any-number of routes -- perl scripting) to the Quagga-Box announce them to your ASR peer via BGP for example.
BR
Orestis
