How to verify the status on the DC power supply on an ASR 9000v (power usage and inputs status).
Gerth Rauseo
Is there any way to verify the status on the DC power supply on an ASR 9000v from the parent ASR 9010? (power usage and inputs status).
So far, the only way I can tell there is a failure on any input is by the CRIT LED on the 9000v itself.
xthuijs
hi gerth, from the XR cli I dont believe that exists. you can go into the satellite cli by telnetting to its address from the 9k host and verify the power there, but then if the power is out, that telnet ain't working either of course ;)
xander
Hi xander,
Thank you for this information, but once connected to the satellite which command can we use to view both DC power input status ? According to this point, is there any reference guide or some pertinent pages where I can find information about how to monitor DC power input of ASR9000v sat through SNMP ?
Thanks for your help.
Rolf
