How to work MPLS packet PIE on ASR9K
saul.reyes
Actually we are trying to operate MPLS LDP on ASR9000 but it,s impossible cause we need to install and active the asr9k-mpls-p.pie-4.2.3, we download the file from cisco but when we put it on disk0: the file doesn´t work property
We tried to install the file.TAR and active but there are a follow error:
RP/0/RSP1/CPU0:ED_MEX_1(admin)#sho install log 43
Thu May  9 13:18:50.132 UTC
Install operation 43 started by user 'ASRadmin' via CLI at 12:37:30 UTC Thu May 09 2013.
    (admin) install add /disk0:ASR9K-iosxr-p-k9-4.2.3.tar activate
    Install operation 43 cancelled by user 'ASRadmin' at 12:59:13 UTC Thu May 09 2013.
Install logs:
    Install operation 43 '(admin) install add /disk0:ASR9K-iosxr-p-k9-4.2.3.tar activate' started by user 'ASRadmin' via CLI at 12:37:30 UTC Thu May 09 2013.
    Warning:  The following file has the suffix '.tar' and will be treated as a tar file:
    Warning:      /disk0:ASR9K-iosxr-p-k9-4.2.3.tar
    Warning:  If a file should not be treated as tar file:
    Warning:   - change the file extension.
    Warning:  To stop this message being displayed:
    Warning:   - use the tar keyword to explicitly specify a tar file.
    Info:     The following files were extracted from the tar file '/disk0:ASR9K-iosxr-p-k9-4.2.3.tar' and will be added to the entire router:
    Info:
    Info:         asr9k-asr9000v-nV-p.pie-4.2.3
    Info:         asr9k-services-p.pie-4.2.3
    Info:         asr9k-p-4.2.0.CSCtx28089.pie
    Info:         asr9k-p-4.2.0.CSCtx28089.txt (skipped - not a pie)
    Info:         asr9k-p-4.1.2.CSCty67156.pie
    Info:         asr9k-p-4.1.2.CSCty67156.txt (skipped - not a pie)
    Info:         asr9k-mini-p.pie-4.2.3
    Info:         asr9k-mini-p.vm-4.2.3 (skipped - not a pie)
    Info:         asr9k-p-4.0.1.CSCto05713.pie
    Info:         asr9k-p-4.0.1.CSCto05713.txt (skipped - not a pie)
    Info:         asr9k-mpls-p.pie-4.2.3
    Info:         asr9k-p-4.2.0.CSCtz65963.pie
    Info:         asr9k-p-4.2.0.CSCtz65963.txt (skipped - not a pie)
    Info:         asr9k-p-4.0.0.CSCtk65746.pie
    Info:         asr9k-p-4.0.0.CSCtk65746.txt (skipped - not a pie)
    Info:         asr9k-mcast-p.pie-4.2.3
    Info:         asr9k-upgrade-p.pie-4.2.3
    Info:         asr9k-p-4.2.0.CSCtl84822.pie
    Info:         asr9k-p-4.2.0.CSCtl84822.txt (skipped - not a pie)
    Info:         asr9k-video-p.pie-4.2.3
    Info:         asr9k-doc-p.pie-4.2.3
    Info:         asr9k-optic-p.pie-4.2.3
    Info:         asr9k-p-4.0.1.CSCtj90504.pie
    Info:         asr9k-p-4.0.1.CSCtj90504.txt (skipped - not a pie)
    Info:         asr9k-p-4.2.0.CSCty98459.pie
    Info:         asr9k-p-4.2.0.CSCty98459.txt (skipped - not a pie)
    Info:         asr9k-p-4.2.0.CSCtz35514.pie
    Info:         asr9k-p-4.2.0.CSCtz35514.txt (skipped - not a pie)
    Info:         asr9k-mgbl-p.pie-4.2.3
    Info:         asr9k-p-4.2.0.CSCua50217.pie
    Info:         asr9k-p-4.2.0.CSCua50217.txt (skipped - not a pie)
    Info:         asr9k-p-4.2.0.CSCtz47970.pie
    Info:         asr9k-p-4.2.0.CSCtz47970.txt (skipped - not a pie)
    Info:         asr9k-p-4.2.0.CSCtx89601.pie
    Info:         asr9k-p-4.2.0.CSCtx89601.txt (skipped - not a pie)
    Info:         asr9k-p-4.2.0.CSCub41271.pie
    Info:         asr9k-p-4.2.0.CSCub41271.txt (skipped - not a pie)
    Info:         asr9k-k9sec-p.pie-4.2.3
    Info:         README-ASR9K-P-k9-4.2.3.txt (skipped - not a pie)
    Info:
    Part 1 of 2 (add software): Started
    Warning:  Packages of the same version must belong to the same subplatform in install inventory. Some packages to be added in this operation have different subplatform
    Warning:  than that of the packages already in install inventory. Following packages will NOT be added in this install operation.
    Warning:      Package Name                Subplatform: Package    Inventory
    Warning:      asr9k-9000v-nV-p-4.2.3                   Default    PX
    Warning:      asr9k-services-p-4.2.3                   Default    PX
    Warning:      asr9k-mini-p-4.2.3                       Default    PX
    Warning:      asr9k-mpls-p-4.2.3                       Default    PX
    Warning:      asr9k-mcast-p-4.2.3                      Default    PX
    Warning:      asr9k-upgrade-p-4.2.3                    Default    PX
    Warning:      asr9k-video-p-4.2.3                      Default    PX
    Warning:      asr9k-doc-p-4.2.3                        Default    PX
    Warning:      asr9k-optic-4.2.3                        Default    PX
    Warning:      asr9k-mgbl-p-4.2.3                       Default    PX
    Warning:      asr9k-k9sec-p-4.2.3                      Default    PX
    Abort this operation? YES to abort, NO to continue [Y]
    User Response:  'y'
automatic the ASR cancel from ASRadmin
¿this Warning is the possible fail?
somebody know what problem is refered to this
Thanks, Best Regards
hi Saul,
On another note I would advise you to review the updated 4.2.3Release Recommendations, and make sure to add
the critical SMU's for any of the feautures your using, and also be sure to load the NP SMU CSCud37351 which supercedes the SMU you have installed (disk0:asr9k-px-4.2.3.CSCuc79084-1.0.0)
http://www.cisco.com/web/Cisco_IOS_XR_Software/pdf/ASR9000_423_Release_Recommendation.pdf
regards,
David
6 Replies 6
Michael Toth
Level 4
Level 4
can you please provide a 'admin show install commit sum' ?
I am thinking that you have a RSP440 and require the PX version of the package
Hi Michael
send you the info
RP/0/RSP1/CPU0:ED_MEX_1(admin)#show install committed summary
Thu May  9 14:15:35.905 UTC
Default Profile:
  SDRs:
    Owner
  Committed Packages:
    disk0:asr9k-mini-px-4.2.3
    disk0:asr9k-k9sec-px-4.2.3
Best Regards
Michael
send you the sho diag from device
NODE module 0/RSP0/CPU0  ASR9K Route Switch Processor with 440G/slot Fabric and 6GB
  MAIN:  board type 0x100306
  S/N:   FOC1646N0ZA
  Top Assy. Number:   68-3938-05
  PID:   A9K-RSP440-TR
  HwRev (UDI_VID):   V02
  Chip HwRev: V1.100
  New Deviation Number: 0
  CLEI:  IPUCA6VBTB
  Board State : IOS XR RUN
  PLD:    Motherboard: N/A, Processor: 0x0 (rev: 2.174), Power: N/A
  MONLIB:
  ROMMON: Version 0.62 [ASR9K x86 ROMMON],
  Board FPGA/CPLD/ASIC Hardware Revision:
    FabSwitch0  : V1.5
    FabSwitch1  : V1.5
    FabArbiter  : V0.0
    FIA  : V0.2
    IntCtrl  : V0.9
    ClkCtrl  : V2.10
    10GPuntFPGA  : V1.6
    HD  : V17.0
    USB0  : V17.0
    USB1  :
    CpuCtrl  : V0.9
    YDTI  : V4.9
    LIU  :
    MLANSwitch  :
    EOBCSwitch  : V0.0
    HostInftCtrl  :
    PHY  : (HwRev)      (FwRev) (SwRev)
    Offload10GE  :
    E10GEDualMAC0  :
    E10GEDualMAC1  :
    EGEDualMAC0  :
    EGEDualMAC1  :
    CBC (active partition)  : v16.115
since you have the 440rsp you need to install the PX version of the mpls package
thanks so much Michael we try to download the file.PX for MPLS
Best Regards
hi Saul,
regards,
David
