Improved wildcard use when removing configuration
Peter L
Any reason why the use of wildcard is so limited in Ios-xr when removing configuration? Know that you can remove all configuration on all  gig interface with no int gig* as an example, but why isn’t there a possibility to do the same with policy-maps/class-maps and all other stuff that you have named.
instead of doing:
no policy-map test1
no policy-map test2
i would like to do
no policy-map test*
Running 5.2.4 at the moment so maybe this is already implemented in newer releases, otherwise it would be a nice to have feature in future releases.
Regards Peter
tkarnani
Hello Peter,
I have tried this in our lab with code 5.3.2 and i am seeing the same behaviour you described.
I have opened an enhancement request CSCux46353 for you.
RP/0/RP0/CPU0:CRS-I#conf t
Tue Dec 8 15:30:15.942 EST
RP/0/RP0/CPU0:CRS-I(config)#no interface gigabitEthernet *
RP/0/RP0/CPU0:CRS-I(config)#no interface tenGigE *
RP/0/RP0/CPU0:CRS-I(config)#no policy-map *
% Invalid input detected at '^' marker.
RP/0/RP0/CPU0:CRS-I(config)#no policy-map*
RP/0/RP0/CPU0:CRS-I(config)#no ip
iphc ipsla ipv4 ipv6
RP/0/RP0/CPU0:CRS-I(config)#no ipv4 access-list *
RP/0/RP0/CPU0:CRS-I(config)#no router *
RP/0/RP0/CPU0:CRS-I(config)#no router ospf *
Thanks for opening an enhancement request for this. Hopefully we can get this functionality in a 6.x.x release next year.
Regards Peter
