01-29-2025 11:25 PM
In A9K-4HG-FLEX-SE , There are 24 number of 10G ports(12 and 12) and 16 number of 10G/25G ports (8 and
What are the port combinations that can be used? For example, if we use 12 x 10G port in one plane, can't we use 10/25G ports at the same plane?
Best Regards,
Madura
01-30-2025 12:57 PM
for example should be able to use this command.
RP/0/RSP1/CPU0:ASR-9906-C-LS#show controllers np valid-port-groups all location 0/3/CPU0
Thu Jan 30 20:56:56.326 UTC
Node: 0/3/CPU0:
NP0: Valid Port Groups
SEL | Group 0 | Group 1 | Group 2 | Group 3
DFLT 1x100GE 1x100GE 1x100GE 1x100GE
1 1x100GE/1x40GE/4x25GE 1x100GE/1x40GE/4x25GE 1x100GE/1x40GE/4x25GE 1x100GE/1x40GE/4x25GE
2 1x100GE/1x40GE/4x25GE 1x100GE/1x40GE/4x25GE 1x100GE/1x40GE/4x25GE 10x10GE/5x1GE_5x10GE/10x1GE
3 1x100GE/1x40GE/4x25GE 1x100GE/1x40GE/4x25GE 10x10GE/5x1GE_5x10GE/10x1GE 10x10GE/5x1GE_5x10GE/10x1GE
4 1x100GE/1x40GE/4x25GE 10x10GE/5x1GE_5x10GE/10x1GE 10x10GE/5x1GE_5x10GE/10x1GE 10x10GE/5x1GE_5x10GE/10x1GE
5 10x10GE/5x1GE_5x10GE/10x1GE 10x10GE/5x1GE_5x10GE/10x1GE 10x10GE/5x1GE_5x10GE/10x1GE 10x10GE/5x1GE_5x10GE/10x1GE
Notes:
DFLT : QSFP port 40, QSFP port 41, QSFP port 42, QSFP port 43 (default)
Group 0: QSFP port 40 or SFP10g port 0-9 or SFP10g port 0-4 SFP1g port 5-9 or SFP25g port 6-9
Group 1: QSFP port 41 or SFP10g port 10-19 or SFP10g port 10-14 SFP1g port 15-19 or SFP25g port 16-19
Group 2: QSFP port 42 or SFP10g port 20-29 or SFP10g port 20-24 SFP1g port 25-29 or SFP25g port 26-29
Group 3: QSFP port 43 or SFP10g port 30-39 or SFP10g port 30-34 SFP1g port 35-39 or SFP25g port 36-39
01-30-2025 04:47 PM
Thanks for the explanation.
In that case, we can use 2 x 100G and 20 x 10G combination from one A9K-4HG-FLEX-SE card. Please correct me if I am wrong.
Best Regards,
Madura
02-03-2025 11:57 AM
Yes you can. just make sure in this combination 100Gs to be used in first 2 groups (Group 0 and Group 1) then Group 2 and Group 3 can be used for 10G ports. you can't use 10G in group 0 and then 100G in group 1 or later.
