03-12-2021 08:13 AM
Hi, I'm trying to accept udp traffic from within a linux container on an ncs 5001.
On the router, the lpts ifib statistics show rejections that increment with each packet I send, so I'm assuming it's blocking my traffic:
#show lpts ifib statistics Fri Mar 12 07:55:27.732 PST Flow Manager 0/RP0/CPU0: Packets in: 140125640905045 Packets delivered locally without lookups: 113 Slice lookups: 140125761577526 Explicit drops: 140125640905045 No-entry drops: 140125761577526 Reject rate-limit drops: 140125640905045 Rejects: 10 # <-- This Increments each time I get a UDP packet packet bound for the container Packets delivered locally: 40 Packets delivered remotely: 0 Statistics last cleared: Fri Mar 12 07:54:50 2021
Looking at the knobs available to me (mostly from this guide), it looks like I can configure rate limits with:
lpts pifib hardware police
but I already have sane-looking settings for udp traffic (nothing with rate 0).
Is there something else that would cause lpts to reject incoming traffic? And if so, how do I configure it?
03-13-2021 06:18 PM
I should note that I have not played around with third-party containers in XR, but this guide seems to make it out like KIM will signal to LPTS for any ports to open.
Did you also set a TPA address for routing between the VM and the outside world?
Sam
03-15-2021 02:37 PM
Thanks for the link to that post! Very helpful details (and seems to mostly agree with the behavior I've been seeing).
To sanity-check myself, I setup a similar test, but with TCP and was able to send and receive traffic normally -- so I think I have the basic routing setup ~correctly and that this seems to affect UDP specifically.
Unfortunately, I'm still at a bit of a loss about what to try next
03-15-2021 06:00 PM
Is there any difference in how the application in the third-party container registers tcp vs udp sockets back to the kernel? I mean do you see the socket as open in both applications in the container? Just no LPTS entry on the XR side?
I would start by getting a show tech lpts and show tech kim, and then we would probably need a TAC case to determine if the right calls between kernel and XR etc are being made.
Sam
03-31-2021 08:38 AM
Sorry for the slow response -- I've filed a TAC case to help figure this out.
Upon further investigation, it looks like the specific way I'm creating the socket isn't being picked up by LPTS (I do a socket() and a bind() -- with no connect()). This shows up in netstat and works on other platforms, so I believe we're just not using whichever syscall KIM is looking for (documentation on what it looks for is unfortunately sparse). This is further confirmed by the fact that if I set up a udp socket with nc, it shows up in LPTS without issue.
I'll update this thread with whatever I find out from the TAC case.
Thanks again for the pointers!
