Input drops on Bundle-ether
hank
We are seeing input-drops on one specific sub-interface of a Bundle-Ether:
Bundle-Ether2.333 is up, line protocol is up
  Interface state transitions: 11
  Hardware is VLAN sub-interface(s), address is 5087.896d.e392
  Internet address is xx.xx.88.94/30
  MTU 9196 bytes, BW 15000000 Kbit (Max: 30000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation 802.1Q Virtual LAN, VLAN Id 333,  loopback not set,
  Last link flapped 04:36:57
  ARP type ARPA, ARP timeout 04:00:00
  Last input 00:00:00, output 00:00:00
  30 second input rate 1000 bits/sec, 1 packets/sec
  30 second output rate 0 bits/sec, 1 packets/sec
     1301507775597 packets input, 1049536070526007 bytes, 168006588 total input drops
So I went to check the following:
RP/0/RSP0/CPU0:GP1#sho controll  np count all loca 0/0/cpu0 | incl DROP
Fri Sep  4 05:35:31.185 IDT
101  RSV_DROP_EGR_UIDB_NO_MATCH                               705           0
103  RSV_DROP_EGR_UIDB_DOWN                                    65           0
113  RSV_DROP_IPV4_NRLDI_NO_MATCH                             997           0
125  RSV_DROP_IPV4_TXADJ_NO_MATCH                               6           0
131  RSV_DROP_IPV4_DROP_NULL_RTE                        173023112           8
137  RSV_DROP_IPV4_DROP_RP_DEST                           3436315           0
141  RSV_DROP_IPV4_RXADJ_DROP                             2915267           0
155  RSV_DROP_ING_LAG_NO_MATCH                             945526           0
157  RSV_DROP_EGR_LAG_NO_MATCH                                  1           0
163  RSV_DROP_QOS_DENY                                   59842111           0
171  RSV_DROP_IPV4_URPF_CHK                                   330           0
173  RSV_DROP_IPV6_URPF_CHK                               4359144           0
289  RSV_DROP_IFIB_TTL_CHECK                                   62           0
450  RSV_EGR_LAG_NOT_LOCAL_DROP_CNT                            28           0
630  MDF_PUNT_POLICE_DROP                             10788586126           0
637  MODIFY_PUNT_REASON_MISS_DROP                               3           0
1074  DROP_FRM_CRC_ERR_XAUI4                                   209           0
1075  DROP_FRM_FRM_ERR_XAUI4                                   535           0
1078  DROP_FRM_CRC_ERR_XAUI6                                    15           0
1080  DROP_FRM_CRC_ERR_XAUI7                                  1452           0
1081  DROP_FRM_FRM_ERR_XAUI7                                   134           0
1215  DROP_FRM_RUNT                                            183           0
1292  PARSE_DROP_IN_UIDB_TCAM_MISS                             376           0
1298  PARSE_DROP_IN_UIDB_DOWN                                  334           0
1302  PARSE_DROP_IPV4_DISABLED                                4051           0
1339  PARSE_DROP_IPV6_LENGTH                                     1           0
1442  L2TP_ING_DECAP_VER_DROP                                   70           0
1480  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_0                   312           0
1481  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_0_MONITOR               304           0
1482  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_1                   279           0
1483  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_1_MONITOR               304           0
101  RSV_DROP_EGR_UIDB_NO_MATCH                                23           0
103  RSV_DROP_EGR_UIDB_DOWN                                    44           0
109  RSV_DROP_IPV4_LEAF_NO_MATCH                             8583           0
113  RSV_DROP_IPV4_NRLDI_NO_MATCH                            1599           0
125  RSV_DROP_IPV4_TXADJ_NO_MATCH                               5           0
131  RSV_DROP_IPV4_DROP_NULL_RTE                         51588147           1
137  RSV_DROP_IPV4_DROP_RP_DEST                          66906156           8
141  RSV_DROP_IPV4_RXADJ_DROP                             2741044           0
155  RSV_DROP_ING_LAG_NO_MATCH                             468907           0
157  RSV_DROP_EGR_LAG_NO_MATCH                                  7           0
161  RSV_DROP_ACL_DENY                                    6697138           0
277  RSV_DROP_NHINDEX                                        1510           0
450  RSV_EGR_LAG_NOT_LOCAL_DROP_CNT                             1           0
630  MDF_PUNT_POLICE_DROP                                 1120222           0
637  MODIFY_PUNT_REASON_MISS_DROP                               2           0
1074  DROP_FRM_CRC_ERR_XAUI4                                    17           0
1075  DROP_FRM_FRM_ERR_XAUI4                                     8           0
1076  DROP_FRM_CRC_ERR_XAUI5                                    23           0
1077  DROP_FRM_FRM_ERR_XAUI5                                     6           0
1080  DROP_FRM_CRC_ERR_XAUI7                                  2712           0
1081  DROP_FRM_FRM_ERR_XAUI7                                   279           0
1292  PARSE_DROP_IN_UIDB_TCAM_MISS                           40330           0
1298  PARSE_DROP_IN_UIDB_DOWN                                   43           0
101  RSV_DROP_EGR_UIDB_NO_MATCH                              1797           0
103  RSV_DROP_EGR_UIDB_DOWN                                   169           0
109  RSV_DROP_IPV4_LEAF_NO_MATCH                                3           0
113  RSV_DROP_IPV4_NRLDI_NO_MATCH                            1180           0
131  RSV_DROP_IPV4_DROP_NULL_RTE                        143632503          11
137  RSV_DROP_IPV4_DROP_RP_DEST                           3326871           0
141  RSV_DROP_IPV4_RXADJ_DROP                             1612571           0
155  RSV_DROP_ING_LAG_NO_MATCH                             446948           0
157  RSV_DROP_EGR_LAG_NO_MATCH                                 23           0
171  RSV_DROP_IPV4_URPF_CHK                               8063285           0
173  RSV_DROP_IPV6_URPF_CHK                               3751447           0
289  RSV_DROP_IFIB_TTL_CHECK                                  118           0
450  RSV_EGR_LAG_NOT_LOCAL_DROP_CNT                           265           0
630  MDF_PUNT_POLICE_DROP                             12963392090           0
1074  DROP_FRM_CRC_ERR_XAUI4                               5807218           1
1075  DROP_FRM_FRM_ERR_XAUI4                                146232           0
1076  DROP_FRM_CRC_ERR_XAUI5                                    15           0
1077  DROP_FRM_FRM_ERR_XAUI5                                     5           0
1078  DROP_FRM_CRC_ERR_XAUI6                                   120           0
1079  DROP_FRM_FRM_ERR_XAUI6                                  1235           0
1080  DROP_FRM_CRC_ERR_XAUI7                                    27           0
1081  DROP_FRM_FRM_ERR_XAUI7                                     8           0
1215  DROP_FRM_RUNT                                            703           0
1298  PARSE_DROP_IN_UIDB_DOWN                                 1157           0
1302  PARSE_DROP_IPV4_DISABLED                                 105           0
1339  PARSE_DROP_IPV6_LENGTH                                    28           0
1442  L2TP_ING_DECAP_VER_DROP                                   58           0
1480  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_0                    98           0
1481  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_0_MONITOR               116           0
1482  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_1                   101           0
1483  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_1_MONITOR               103           0
101  RSV_DROP_EGR_UIDB_NO_MATCH                               145           0
103  RSV_DROP_EGR_UIDB_DOWN                                  1661           0
109  RSV_DROP_IPV4_LEAF_NO_MATCH                              425           0
113  RSV_DROP_IPV4_NRLDI_NO_MATCH                             746           0
125  RSV_DROP_IPV4_TXADJ_NO_MATCH                              42           0
131  RSV_DROP_IPV4_DROP_NULL_RTE                         32538545           1
137  RSV_DROP_IPV4_DROP_RP_DEST                           5883316           0
141  RSV_DROP_IPV4_RXADJ_DROP                             1218269           0
155  RSV_DROP_ING_LAG_NO_MATCH                             197803           0
157  RSV_DROP_EGR_LAG_NO_MATCH                                719           0
161  RSV_DROP_ACL_DENY                                    6698807           0
163  RSV_DROP_QOS_DENY                                   37257510           0
171  RSV_DROP_IPV4_URPF_CHK                                 71020           0
173  RSV_DROP_IPV6_URPF_CHK                               8114060           0
289  RSV_DROP_IFIB_TTL_CHECK                                  197           0
450  RSV_EGR_LAG_NOT_LOCAL_DROP_CNT                          2401           0
630  MDF_PUNT_POLICE_DROP                             50209728832           0
1074  DROP_FRM_CRC_ERR_XAUI4                                    55           0
1075  DROP_FRM_FRM_ERR_XAUI4                                    74           0
1078  DROP_FRM_CRC_ERR_XAUI6                                   380           0
1079  DROP_FRM_FRM_ERR_XAUI6                                    46           0
1080  DROP_FRM_CRC_ERR_XAUI7                                   700           0
1081  DROP_FRM_FRM_ERR_XAUI7                                  1946           0
1215  DROP_FRM_RUNT                                            283           0
1298  PARSE_DROP_IN_UIDB_DOWN                                  867           0
1302  PARSE_DROP_IPV4_DISABLED                                2585           0
1339  PARSE_DROP_IPV6_LENGTH                                    41           0
1442  L2TP_ING_DECAP_VER_DROP                                  124           0
1480  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_0                   764           0
1481  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_0_MONITOR               775           0
1482  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_1                   751           0
1483  PARSE_FAST_DISCARD_LOW_PRIORITY_DROP_1_MONITOR               797           0
But I cannot find any documentation on MDF_PUNT_POLICE_DROP  nor on any SRV_DROP string.  The document: https://community.cisco.com/t5/service-providers-documents/asr9000-xr-troubleshooting-packet-drops-and-understanding-np/ta-p/3126715
which documents what the various fields mean does not document anything on these 2 strings.
So I am at a loss to figure out why I am seeing input drops on one specific bundle sub-interface.
We are running 5.3.3 on ASR9010 and the config for the sub-interface is as follows:
interface Bundle-Ether2.333
bandwidth 15000000
service-policy input limit-ddos-in
ipv4 mtu 1500
ipv4 address xx.xx.88.94 255.255.255.252
ipv4 verify unicast source reachable-via any allow-self-ping allow-default
ipv6 nd dad attempts 5
ipv6 mtu 1500
ipv6 verify unicast source reachable-via any allow-self-ping allow-default
ipv6 address xxx:798:1::72/126
ipv6 address xxx:7f8:3c::6e/126
ipv6 enable
monitor-session No1 ethernet
Any help or clue would appreciated.
smilstea
A lot of these would cause drops, the problem being its an aggregate on the NP and of course the bundle could be spread out on multiple NPs or LCs.
The easiest way is to check the NP buffer for dropped packets or do a manual np capture to look for drops. show controller np capture or monitor np.
The punt police is related to show lpts pifib hardware police loc <> drops for punted control plane traffic, and the qos deny is due to policer etc, show qos int <>. If you have a support contract we can help you easier by having someone in TAC check the box for you and find the cause of the drops.
Sam
