Insert A9K-MOD160-SE A9K-MPA-8X10GE
EA-6901000101
Hi Guys, I read the Installing and Removing Line Cards and Transceiver Modules, for A9K-MOD-160 and A9K-MPA-8X10GE, so just two question:
* Before insert the A9K-MOD-160 is required insert the A9K-MPA-8X10GE module onto Line Card? Or Insert A9K-MOD-160 into ASR9010 after that installa the module A9K-MPA-8X10GE.
* License L3VPN is requiered copy to Slot where inserted the A9K-MOD-169 Line Card?
That's the correct procedure or some one can recommend other steps
Thanks in advanced
tkarnani
>>> The MPA's are designed to be hot swapped, you can do it before or after, shouldnt matter
>>> If you are configuring vrfs on the LC, yes you require a license attached to the card, admin show license should tell you if there is one
