ASR9001 Upgrade path issues
Hi all,
l am running a 9001 IOS-XR image - Currently 6.1.4
I need to upgrade this to 6.6.3 , but I am unsure of the upgrade path, can I go straight from 6.1.4 to 6.6.3/6.7.1 or will have to increment to specify versions?
- l checked the Cisco download page but could not find the release notes - upgrade path;
This is my first upgrade and I cannot find any informative guides as the Cisco.
Related Links and Documentation
- No related links or documentation -
So far I have downloaded ASR9K-iosxr-px-6.6.3.tar, but a few questions including the one above are;
Does the tar file include the new root certificate (I assume this tar file needs to be unpacked and cert installed separately if included)?
What is the difference between following TAR files:
Cisco ASR 9000 IOS XR Software
ASR9K-px-docs-6.6.3.tar
Any recommendations of upgrade guides ?
There maybe more questions to add as I run through the documentation to get more information.
Thanks for the input in advance
2 Accepted Solutions
tkarnani
yes you can upgrade from 6.1.4 to 663
the upgrade document pdf is inside this tar file ASR9K-px-docs-6.6.3.tar
the actual packages/software is inside this tar file ASR9K-iosxr-px-6.6.3.tar
there is another variation of ASR9K-iosxr-px-6.6.3.tar with K9 in the filename, which has the k9 pie for SSH if required
Thanks!
Lawful intercept feature requires a license.
if you are not using this feature, you can remove this package disk0:asr9k-li-6.3.3
the 2nd set of messages are asking to upgrade the FPD, the firmware on the ASIC.
it is recommended to do so as part of the upgrade.
admin upgrade hw-module fpd all location all
this command will start the upgrade process for all of line cards
admin upgrade hw-module fpd all location pm-all
this command will upgrade the power modules if they require them
tkarnani
Thanks!
hi,
any thoughts on these messages we got during install for license and upgrade hw-module fpd: ?
install add tar disk1:ASR9K-iosxr-px-k9-6.4.4.tar activate
"show install log detail":
Info:
Part 1 of 2 (add software): Completed successfully
Part 2 of 2 (activate software): Started
Warning:  There is no valid license for the following package:
Warning:
Warning:      disk0:asr9k-li-6.3.3
Warning:
Info:     This operation will reload the following nodes in parallel:
then after reboot we got
LC/0/0/CPU0: lda_server[64]:
%PLATFORM-UPGRADE_FPD-4-DOWN_REV : fpga3 instance 0 is down-rev (V1.00),
upgrade to (V1.01). Use the "upgrade hw-module fpd" CLI in admin mode.
LC/0/0/CPU0: rommon_fpd_agent[337]:
%PLATFORM-UPGRADE_FPD-4-DOWN_REV : rommon instance 0 is down-rev
(V2.04), upgrade to (V3.04). Use the "upgrade hw-module fpd" CLI in
admin mode.
