IOS XE to IOS XR conversion tool
Does anyone know of a tool to convert a IOS XE configuration to IOS XR?
Warm Regards
Francois
Jaime Saldana Morales
 Hi francois.pieterse,
From Cisco.com you can use the Cisco Active Advisor which it offers an automatic conversion from IOS configurations to IOS XE.
IOS to IOS XE Converter
https://help.ciscoactiveadvisor.com/support/home
Jaime Saldana
Elvin Arias
For IOS XE to IOS-XR, open a TAC case and request the engineer to convert the config for you.
Elvin
joseph.call84
I can confirm that the Cisco-internal tool SoX is still in-use and Cisco support can translate XE configs into XR configs. There is some level of sanity-checking involved and it may not match your intent, but it saves a LOT of time to get the base XR template from XE, which can be modified.
We had a Cisco XE specialist and an XR specialist on a phone call during a regular sync meeting with Cisco at our company, and they collaborated and provided an output XR file using SoX based on an XE config that I gave them. They provided this file same-day, so it appears to be a quick process.
Output at the top of the converted file:
! Configuration file converted by:
! SoX Tool (v50.00) [http://xrgeeks.cisco.com/sox/Sox_Tool.html]
! for IOS-XR Release (R5.3) at 21:10:41 12/03/24 UTC
! Caveat Emptor: This file has been generated by an automated tool.
! No guarantee is offered with respect to accuracy
! and/or suitability of the results.
! The consumer of this file is responsible to:
! o apply appropriate sanity-checking
! o detect omissions
! o correct errors
