IOS XR recovery failure help
glenthms
This 9001 router is stuck in boot loop and I have yet to figure this out.  Ive tried 6.1.4 vm file and 4.3.4 vm file load from rommon boot using tftp but neither works.  I get the below errors when I get vm loaded from rommon.  The install completes but I have no ability to configure interface to do anything and then it reboots at the end.  Anyone have any ideas how to save this?
Process 8380612 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:07:47.332 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:07:47.333 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 108) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:07:57.549 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:07:57.549 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
Process 8384708 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:07:57.549 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8384708 (pkg/bin/dao_tmp)
RP/0/RSP0/CPU0:Feb 11 02:07:57.588 : dumper[60]: %OS-DUMPER-3-PATH_FAILED : Core dump for pkg/bin/dao_tmp failed due to lack of working dump path choice
RP/0/RSP0/CPU0:Feb 11 02:07:57.632 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:07:57.632 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 109) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:08:07.852 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:08:07.852 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:08:07.852 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8388804 (pkg/bin/dao_tmp)
Process 8388804 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:08:08.838 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:08:08.839 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 110) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:08:19.055 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:08:19.055 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:08:19.055 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8392900 (pkg/bin/dao_tmp)
Process 8392900 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:08:19.995 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:08:19.996 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 111) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:08:30.211 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:08:30.211 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:08:30.211 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8396996 (pkg/bin/dao_tmp)
Process 8396996 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:08:31.179 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:08:31.180 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 112) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:08:37.439 : online_diag_rsp[450]: %DIAG-DIAG-3-GOLDXR_FAIL : ClkCtrlScratchRegister ERROR: 0x16: Invalid argument
RP/0/RSP0/CPU0:Feb 11 02:08:41.402 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:08:41.402 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
Process 8401092 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:08:41.402 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8401092 (pkg/bin/dao_tmp)
RP/0/RSP0/CPU0:Feb 11 02:08:41.440 : dumper[60]: %OS-DUMPER-3-PATH_FAILED : Core dump for pkg/bin/dao_tmp failed due to lack of working dump path choice
RP/0/RSP0/CPU0:Feb 11 02:08:41.482 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:08:41.483 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 113) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:08:51.698 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:08:51.698 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:08:51.698 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8405188 (pkg/bin/dao_tmp)
Process 8405188 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414 bdslot=1
RP/0/RSP0/CPU0:Feb 11 02:08:52.635 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:08:52.635 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 114) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:09:02.849 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:09:02.849 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:02.849 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8409284 (pkg/bin/dao_tmp)
Process 8409284 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:03.794 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:09:03.795 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 115) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:09:14.012 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:09:14.012 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:14.012 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8413380 (pkg/bin/dao_tmp)
Process 8413380 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:14.050 : dumper[60]: %OS-DUMPER-3-PATH_FAILED : Core dump for pkg/bin/dao_tmp failed due to lack of working dump path choice
RP/0/RSP0/CPU0:Feb 11 02:09:14.092 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:09:14.092 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 116) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:09:24.315 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:09:24.315 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:24.315 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8417476 (pkg/bin/dao_tmp)
Process 8417476 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:25.287 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:09:25.288 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 117) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:09:35.521 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:09:35.521 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:35.521 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8421572 (pkg/bin/dao_tmp)
Process 8421572 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:35.560 : dumper[60]: %OS-DUMPER-3-PATH_FAILED : Core dump for pkg/bin/dao_tmp failed due to lack of working dump path choice
RP/0/RSP0/CPU0:Feb 11 02:09:35.601 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:09:35.602 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 118) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:09:37.440 : online_diag_rsp[450]: %DIAG-DIAG-3-GOLDXR_FAIL : ClkCtrlScratchRegister ERROR: 0x16: Invalid argument
RP/0/RSP0/CPU0:Feb 11 02:09:45.817 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:09:45.817 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:45.817 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8425668 (pkg/bin/dao_tmp)
Process 8425668 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:46.758 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:09:46.759 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 119) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:09:56.979 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:09:56.979 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:56.979 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8429764 (pkg/bin/dao_tmp)
Process 8429764 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:09:57.963 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:09:57.964 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 120) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:10:08.185 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:10:08.185 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:08.185 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8433860 (pkg/bin/dao_tmp)
Process 8433860 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:09.146 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:10:09.146 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 121) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:10:19.364 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:10:19.364 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:19.364 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8437956 (pkg/bin/dao_tmp)
Process 8437956 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:20.324 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:10:20.325 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 122) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:10:30.548 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:10:30.548 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:30.548 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8442052 (pkg/bin/dao_tmp)
Process 8442052 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:30.590 : dumper[60]: %OS-DUMPER-3-PATH_FAILED : Core dump for pkg/bin/dao_tmp failed due to lack of working dump path choice
RP/0/RSP0/CPU0:Feb 11 02:10:30.633 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:10:30.634 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 123) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:10:37.441 : online_diag_rsp[450]: %DIAG-DIAG-3-GOLDXR_FAIL : ClkCtrlScratchRegister ERROR: 0x16: Invalid argument
RP/0/RSP0/CPU0:Feb 11 02:10:40.854 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:10:40.854 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:40.855 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8446148 (pkg/bin/dao_tmp)
Process 8446148 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:41.833 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:10:41.834 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 124) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:10:52.058 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:10:52.058 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:52.059 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8450244 (pkg/bin/dao_tmp)
Process 8450244 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:10:53.008 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:10:53.009 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 125) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:11:03.220 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:11:03.220 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:11:03.221 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8454340 (pkg/bin/dao_tmp)
Process 8454340 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:11:04.194 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:11:04.195 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 126) will be respawned in 10 seconds
RP/0/RSP0/CPU0:Feb 11 02:11:14.410 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:11:14.410 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:11:14.410 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8458436 (pkg/bin/dao_tmp)
Process 8458436 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:11:15.373 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:11:15.374 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 127) will be respawned in 10 seconds
%C-MC-CHECKER-3-DEBUG : Excess 128 MC errors
RP/0/RSP0/CPU0:Feb 11 02:11:25.584 : dumper[60]: %OS-DUMPER-4-SIGBUS_INFO : Thread 1 received SIGBUS - Bus error
RP/0/RSP0/CPU0:Feb 11 02:11:25.585 : dumper[60]: %OS-DUMPER-4-BUS_ADRERR : Signal code 2 - BUSADRERR. Trying to access non-existent physical address f50bf414 at PC f50bf414
RP/0/RSP0/CPU0:Feb 11 02:11:25.585 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 8462532 (pkg/bin/dao_tmp)
Process 8462532 (dao_tmp) terminated SIGBUS code=2 fltno=41 ip=f50bf414
RP/0/RSP0/CPU0:Feb 11 02:11:26.514 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(1) (jid 55) exited, will be respawned with a delay (slow-restart)
RP/0/RSP0/CPU0:Feb 11 02:11:26.515 : sysmgr[97]: %OS-SYSMGR-3-ERROR : dao_tmp(55) (fail count 128) will be respawned in 10 seconds
%C-MC-CHECKER-3-DEBUG : Shutting down node due to excess 129 MC errors
RP/0/RSP0/CPU0:Feb 11 02:11:36.727 : dumper[60]:reboot internal : cause code 134217749 cause Excess Machine Check Condition
reboot_internal timeout 30 is %OS-DUMPER-4-SIgracGBUS_INFO : Threeful no
ELBC LTESR : 0x80000000
[0x1218f9e55e] Record Reboot History, reboot cause = 0xc000015, descr = Cause: Excess Machine Check Condition Process: p40x0mc Traceback: f4884654 f488[0x1219d84839] Initializing harddisk file system
[0x1223ee8673] Uninitialized harddisk partition table entry 0, expecting 80
[0x12243017f2] Initializing bootflash file system
[0x12245cbd62] Record CCSR information
Writing CCSR done
Dump Directory
KD: RSP0.200211-021137.e500, start = 1c01000, size = c710, crc = 0
rebooting
cgNsRԤѕɅUʪWɥBʢj͍ͱJ卹jRԤ W$MKP4 12:08 by nidutta
Starting Initialization of FMAN0
***PPC PROCESSOR REV=3 load FMAN ucode***
Loading ucode for FMAN0, size: 6992, ver: 101.08.00
Starting Initialization of FMAN1
Loading ucode for FMAN1, size: 6992, ver: 101.08.00
Serdes Protocol: 0x10
CPU Reset Reason = 0x0001
Initializing GIGE SW...
PPC P40X0 (partnum 0x8023), Revision 03.00, (Core Version 03.01)
Sys Clock: 100 Mhz
Core Clock: 1500 Mhz
Plat Clock: 800 Mhz
LBC Clock: 25 Mhz
MEM Clock: 1300 Mhz
System Bootstrap, Version 2.04(20140424:063844) [ASR9K ROMMON],
Copyright (c) 1994-2014 by Cisco Systems, Inc.
Compiled Thu 24-Apr-14 12:08 by nidutta
Board Type: 0x100401
CPU Board => Rev: 0x3
FPGA ver: 01.0f
CBC: 16.72
DTI programmed with latest image
TIMEX programmed with latest image
MLAN init done: ready to connect to the network
BCM5482PhyInit () : Port 0 --> SFP Not present
BCM5482PhyInit () : Port 1 --> SFP Not present
set_chassis_type: chassis_type=0xef0400 found=TRUE
ASR9001E (P40X0 PPC) RSP platform with 8192 Mb of main memory
program load complete, entry point: 0x100000, size: 0x2ac20
Set baud rate to: 9600
Fail to open file name mbi_image
CARD_SLOT_NUMBER: 0
CPU_INSTANCE: 1
MBI Validation starts ...
Disabling both Mgt LAN ports
Enabling Cluster Port 0 and disabling Port 1
BCM5482 cluster port-1 reset done !!
Port 0. SFP Not Ready (0:0). Init failed
using TSEC.
dtsec_init_hw: configuring DTSEC (port 8) for: 1GB, Full Duplex
Interface link changed state to UP.
Interface link state up.
MBI validation sending request.
HIT CTRL-C to abort
No MBI confirmation received from dSC
CARD_SLOT_NUMBER: 0
CPU_INSTANCE: 1
Enabling Cluster Port 1 and disabling Port 0
BCM5482 cluster port-0 reset done !!
Port 1. SFP Not Ready (0:0). Init failed
using TSEC.
HIT CTRL-C to abort
AUTOBOOT: Boot string = <not set>
AUTOBOOT: autobootstate=0, autobootcount=0, cmd=boot
Boot Status 16
CARD_SLOT_NUMBER: 0
CPU_INSTANCE: 1
using TSEC.
HIT CTRL-C to abort
0 Replies 0
