IOS-XR - RIPv2 on PPPoE, its possible ?
ndebrigode
Hi all,
I have an ASR9K with BNG and a CPE that connects to PPPoE on my ASR9K.
I try RIPv2 between my CPE and my PE but impossible to send and receive my routes.
With debug, I have this:
rip [1058]: ignored packet from 172.27.50.10 (could not find interface)
The problem is that in the RIP router configuration, I can not set PPPoE interface.
It works perfectly on an IOS-XE, but I could define a "network subnet".
I missed something, here is an example of my configuration :
My ASR9K:
interface GigabitEthernet0/0/0/19.1799
 service-policy type control subscriber PPP_PM
 pppoe enable bba-group DEDE
 encapsulation dot1q 1799
dynamic-template
 type ppp PPP
  ppp authentication chap pap
   accounting aaa list default type session
  ipv4 verify unicast source reachable-via rx
pppoe bba-group DEDE
 service selection disable
class-map type control subscriber match-any PPP
 match protocol ppp
end-class-map
policy-map type control subscriber PPP_PM
 event session-start match-first
  class type control subscriber PPP do-until-failure
   1 activate dynamic-template PPP
 event session-activate match-first
   10 authenticate aaa list default
 end-policy-map
router rip
 vrf TEST
  interface gigabitEthernet 0/0/0/19.1799
  neighbor 172.27.50.10
  route-policy pass-all in
My PPPoE Interface :
RP/0/RSP0/CPU0:ASR9K-TEST#sh subscriber session all
Mon Nov 19 09:56:21.301 CET
Codes: IN - Initialize, CN - Connecting, CD - Connected, AC - Activated,
ID - Idle, DN - Disconnecting, ED - End
Type Interface State Subscriber IP Addr / Prefix
LNS Address (Vrf)
PPPoE:PTA Gi0/0/0/19.1799.pppoe191 AC 172.27.50.10 (TEST)
BR
Nick
Aleksandar Vidakovic
IGP over subscriber interfaces is not supported. If you want dynamic routing with a CPE, you can use eBGP.
