IOS XR SNMP monitor graph unstable
jngjng42
hello.
I am using PRTG to monitor router ASR9910.
The SNMP interface sensor traffic graph appears zigzagging.
The scan interval is also set to 1 minute.
I heard that some people solved the problem with ifmib cache, so I applied it, but the graph remains zigzag.
If you know a solution, please share.
Ruben Cocheno
@jngjng42
Found a few bugs related to the ifmib cache, but when polling is lower than what you using. Probably updating MIBS on PRTG?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
tkarnani
https://community.cisco.com/t5/service-providers-knowledge-base/asr9000-xr-understanding-snmp-and-troubleshooting/ta-p/3144621
ifmib stats cache; it collects all the data from all the interfaces every 30 seconds
the issue is that when you poll every minute, it doesn't refresh the stats cache. this cache timer is independent.
for example
poll 1: stats cache just refreshed 0 seconds; accurate if counters
poll 2: stats cache 25 seconds old ; traffic dip
poll 3: stats cache 3 seconds old; traffic spike
this internal timer is not tracked with snmp and can give the impression of a microburst
