12-06-2023 04:26 AM
I am getting the following error message on an ASR 9006 router "vlan_ea[396]: %ETHER_EA-3-TCAM_REGION_OOR : Error during TCAM allocation, TCAM Region 3 has ran out of resources"
How can I check which TCAM space/region is exhausted and how to check which is the upper limit?
12-06-2023 05:08 AM
you can check via this command, it will print each region
show prm server tcam summary all all all location 0/x/CPU0
12-06-2023 05:19 AM
I already run these commands but I didn't located the region. The output is the following:
show prm server tcam summary all all all location 0/0/CPU0
Node: 0/0/CPU0:
TCAM summary for NP0:
TCAM Logical Table: TCAM_LT_L2 (1)
Partition ID: 0, priority: 2, valid entries: 1, free entries: 255
Partition ID: 1, priority: 2, valid entries: 0, free entries: 256
Partition ID: 2, priority: 0, valid entries: 0, free entries: 256
Partition ID: 3, priority: 0, valid entries: 0, free entries: 4096
Partition ID: 4, priority: 0, valid entries: 1, free entries: 19711
TCAM Logical Table: TCAM_LT_ODS2 (2), free entries: 16443, resvd 128
ACL Common Region: 0 entries allocated. 0 entries free
Application ID: NP_APP_ID_IFIB (0)
Total: 1 vmr_ids, 8005 active entries, 8005 allocated entries.
Application ID: NP_APP_ID_QOS (1)
Total: 0 vmr_ids, 0 active entries, 0 allocated entries.
Application ID: NP_APP_ID_ACL (2)
Application ID: NP_APP_ID_AFMON (3)
Application ID: NP_APP_ID_LI (4)
Application ID: NP_APP_ID_PBR (5)
TCAM Logical Table: TCAM_LT_ODS8 (3), free entries: 3365, resvd 128
Total: 1 vmr_ids, 603 active entries, 603 allocated entries.
Application ID: NP_APP_ID_EDPL (6)
TCAM summary for NP1:
TCAM summary for NP2:
Partition ID: 0, priority: 2, valid entries: 2, free entries: 254
Partition ID: 3, priority: 0, valid entries: 3, free entries: 4093
TCAM summary for NP3:
show prm server tcam summary all all all location 0/1/CPU0
Node: 0/1/CPU0:
Partition ID: 3, priority: 0, valid entries: 4096, free entries: 0
Partition ID: 4, priority: 0, valid entries: 4097, free entries: 15615
Partition ID: 4, priority: 0, valid entries: 4095, free entries: 15617
12-06-2023 05:57 AM
12-06-2023 07:05 AM
NP0, LC1
you can see free entries are 0
show controller np ports all location 0/1/cpu0 << check the port mapping for np0
Partition 3; is usually used for l2interfaces please check the scale
12-06-2023 07:29 AM
Thank you for the info. Is there any specific location to check the scale? The line card is one A9K-2x100GE-TR
12-06-2023 09:03 AM
we can check show im database brief location 0/x/cpu0 , it should list all the interfaces
show controller np ports all location 0/1/cpu0 ; will show the interfaces mapped to the NPU0 which is reporting tcam full
12-06-2023 09:39 AM
Sorry for the misunderstanding, but i am referring to the scale of the platform. I indeed have 4096 l2transport subinterfaces. So, is this a generic scale limitation or it is only on my platform with A9K-2x100GE-TR LC?
12-06-2023 09:48 AM
The scale is per line card as the TCAM is on each line card.
each line card will have a different value for tcam space
12-06-2023 12:18 PM
Thanks for the answers. So, Is there any document that describes the partitions usage eg how did you know that the partition 3 is about l2transport interfaces? Is this documented somewhere?
