Bookmark
Subscribe
2718
IOS-XRV Image for testing Segment Routing Features
aviadvigatel1
I am looking for an IOS XRv image that will allow to test the latest segment routing features.
The simulator that I have is EVE-NG.
My understanding is that there used to be IOS Xrv demo image.
From where I can download it.
Apologies if this is not the right board to ask the question.
Thanks a lot.
tkarnani
XRv is not longer released, you will need to load XRv9k, you can download here
https://software.cisco.com/download/home/286288939/type/280805694/release/7.4.1
there are some features that will require real hardware in order to work, you will need to check the release notes to see what is supported
https://www.cisco.com/c/en/us/td/docs/routers/virtual-routers/xrv9k-74x/release/notes/b-release-notes-xrv9000-r741.html
Hi Tkarnani,
Thank you very much for your reply.
The link for the XRv9K that you have provided, needs a "Service Contract" or requires that individual must be a part of Corporation/Reseller that has commercial link with Cisco.
Assunimg that an individual cannot satisfy above two requirements, what other options are availablle?
Does the XRv9K image provided in CML supports all the segment-routing features that may be available on actual platform.
you will need a support contract or a partner account.
Possibly a sales/account team member can get you a demo of it, you will need to check with them to see what you cant do.
XRv9k is the virtualized version of the asr9000, the features will be configurable, however some of them will require real hardware. it would be best to check the specific feature in the version you have and compare the release notes to see what is officially supported
