11-19-2018 04:41 AM
Hi guys,
thanks for an awesome resource!
I've run into a small problem in my L2 lab. I've managed to find an XRv image with a working L2 dataplane but with packet loss it seems.
I was testing the XRv image with a multi segment xconnect setup. So i effectively stitch 2 PW's together on a 3rd PE. Anyway when pinging across the evc, there is connectivity. But packets are dropped at the ACs towards the CPEs. Either side shows this issue, two different PEs. This is what i see:
<snip>
CPE6#ping 1.1.1.7 rep 10000
Sending 10000, 100-byte ICMP Echos to 1.1.1.7, timeout is 2 seconds:
<snip>
The lab runs in esxi 6.5 on a PowerEdge R630 with 2 CPUs and 256Gb memory. The host shows free cpu, mem and disk, plenty infact. PEs are XRv 6.4.1 while the CPEs are CSR1000Vs 16.06.04
Does anyone have any suggestions as to why this happens? Or what can be done? To me it looks like some kind of buffer issue. It looks pretty even and keeps going like that for the duration. I haven't seen any other issues yet.
Any input appreciated!
Thanks in advance.
Cheers
/Kim Tingkær
Solved! Go to Solution.
11-20-2018 12:52 AM
11-20-2018 12:52 AM
11-20-2018 03:47 AM
11-20-2018 07:23 AM
11-20-2018 12:44 PM
LPTS only comes into play when the packets have to be punted up to the CPU (either destined to that router, fragmentation, etc), it shouldn't affect transit traffic between the two CPEs.
Sam
11-20-2018 10:58 PM
Hey guys,
no problems experienced when pinging from PE to PE.
It most definitely is the license limitation :)
Thanks again!
/Kim
