Is this 12000 OS same as OS running in the ASR 9000?
news2010a
Level 3
Level 3
Hello folks,
I need to practice configuration on the ASR 9000 platform.
Question:
Can you confirm the router 12000 running XR below is pretty much the same OS I will find in the ASR 9000 right?
RP/0/0/CPU0:XR01#       show ver
Mon Feb 17 23:18:53.699 UTC
Cisco IOS XR Software, Version 3.9.1[00]
Copyright (c) 2010 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 12.0(20040128:214555) [assafb-PRP1P_20040101 1.8d
ev(2.83)] DEVELOPMENT SOFTWARE
Copyright (c) 1994-2004 by cisco Systems,  Inc.
XR01 uptime is 1 week, 3 days, 11 hours, 16 minutes
System image file is "disk0:c12k-os-mbi-3.9.1/mbiprp-rp.vm"
cisco 12008/PRP (7457) processor with 2097152K bytes of memory.
7457 processor at 1266Mhz, Revision 1.1
1 Cisco 12000 Series Performance Route Processor
1 Cisco 12000 4 Port Gigabit Ethernet Controller (4 GigabitEthernet)
1 4 port ISE OC3 Controller (4 POS)
3 Management Ethernet
4 SONET/SDH
4 Packet over SONET/SDH
1 PLIM_QOS
4 GigabitEthernet/IEEE 802.3 interface(s)
1018k bytes of non-volatile configuration memory.
984304k bytes of disk0: (Sector size 512 bytes).
65536k bytes of Flash internal SIMM (Sector size 256k).
Nicolas Fevrier
it's indeed an IOS XR but:
- you'll find some platform specific functions, outputs, ...
- it's a fairly old version (3.9.1)
But I suppose if you want to practice platform-independant features like routing, management, ... It can do the job.
Cheers,
N.
Rivalino Tamaela
You are limited to platform-independent configuration only, and those PI features are same. Bridge-domain, some L2 features, SPAN can only be done in asr9k.
riv
Saurabh Sharma
if you meant that can you boot 12k using 9k image ?  no you can't do that.
Moreover every platform has there own capablities and set of features which set them apart from each others.Those can be platform specific features and platform independent fetaures as well.
Same as you have IOS that can be used to boot 7600 and c10k boxes but they are not same there images are not same. in 12k and 9k only similarity is there are using ios-xr as there base OS.
