RPL For Route Distribution
djherteen
Greetings,
I'm running an ASR9010 running XR version 4.2.0 and have a scenario where by default I redistribute connected routes into OSPFv2 with the default type-2 metric.
However I have turned up a new peering link off of this PE router and need to redistribute that particular connected prefix as a OSPFv2 type-1.
I thought about attaching the following RPL at the redistribution point:
route-policy MODIFY_TO_TYPE1
   if protocol is connected and (destination in (X.X.X.X/30)) then
     set metric-type type-1
   else
     pass
   endif
   end-policy
Does this look solid? Or should I have (source in (x.x.x.x/30))
Any help would be appricated.
Rivalino Tamaela
Use destination instead of source. Since you are redistributing connected already under ospf command, you do not need to put protocol as connected under route-policy. I did quick test in my lab to show you:
RP/0/RSP0/CPU0:ASR9006-J#show run route-policy RTAMAELA
Tue Mar  4 16:30:15.345 EST
  if destination in (192.168.103.0/24) then
  else
    pass
  endif
end-policy
RP/0/RSP0/CPU0:ASR9006-J#show run router ospf 11
Tue Mar  4 16:30:18.872 EST
router ospf 11
router-id 10.22.65.14
auto-cost reference-bandwidth 10000
redistribute connected route-policy RTAMAELA
area 0.0.0.0
  mpls traffic-eng
  interface Loopback111
   passive enable
  interface GigabitEthernet0/2/1/13
   cost 10
   network point-to-point
   hello-interval 1
  interface GigabitEthernet0/2/1/14
   cost 10
   hello-interval 1
  interface GigabitEthernet0/2/1/19
   cost 10
   hello-interval 1
RP/0/RSP0/CPU0:ASR9001-B#show route | in 192.168
Tue Mar  4 20:31:25.961 UTC
O E2 192.168.9.8/30 [110/20] via 10.22.65.34, 00:04:17, GigabitEthernet0/0/0/3
C    192.168.28.0/24 is directly connected, 06:48:03, Loopback0
L    192.168.28.254/32 is directly connected, 06:48:03, Loopback0
O E2 192.168.29.29/32 [110/20] via 10.22.65.34, 00:04:17, GigabitEthernet0/0/0/3
O E1 192.168.103.0/24 [110/30] via 10.22.65.34, 00:02:48, GigabitEthernet0/0/0/3  <-- the prefix is advertised as E1.
O E2 192.168.110.0/30 [110/20] via 10.22.65.34, 00:04:17, GigabitEthernet0/0/0/3
HTH,
rivalino
Rivalino Tamaela
  else
    pass
  endif
end-policy
router ospf 11
area 0.0.0.0
  mpls traffic-eng
   passive enable
   cost 10
   hello-interval 1
   cost 10
   hello-interval 1
   cost 10
   hello-interval 1
HTH,
rivalino
Rivalino,
Thanks for taking the time to respond to my submmision and the lab testing.
I wanted to let you know that this morning I implemented the RPL as you suggested and it worked as you expected.
I see now I was thinking too much about where the source of the route was originated and not where it was when I needed to modify it.
Thanks again for your help regarding this question!
