ISM with NAT44 - Need help with configuration
Renato Reis
Hello everyone,
I'm trying to set up NAT44 in the following scenario below and I'm having a hard time figuring out how to redirect the traffic. As you can see the big problem is that I have one single interface that connects to the internal network (10.0.0.0/8) and also to the tunnel destinations all in the same VRF. Can you guys give me a hand? The trafiic comes from network network 10.0.0.0/8 enters interface bundle-ether 2 (Now it needs to be translated), once it is translated, now it needs to reach the destination known via GRE tunnel.
Configurations
vrf NAT_IN
address-family ipv4 unicast
vrf BLUE
hw-module service cgn location 0/3/CPU0
interface Bundle-Ether2
description UPLINK TO METRO ETHERNET
interface Bundle-Ether2.2 l2transport
encapsulation dot1q 2
rewrite ingress tag pop 1 symmetric
interface GigabitEthernet200/0/0/43
description LINK TO METRO ETHERNET
bundle id 2 mode active
interface GigabitEthernet300/0/0/43
interface BVI2
description METRO
vrf BLUE
ipv4 address 100.0.0.10/24
interface tunnel-ip 101
description GRE_TUNNEL
vrf BLUE
ipv4 address 1.1.1.1/32
tunnel mode gre ipv4
tunnel source interface bvi 2
tunnel destination 200.0.0.1
interface BVI 100
vrf BLUE
ipv4 address [GATEWAY_100] [MASK_100]
interface BVI 200
vrf BLUE
ipv4 address [GATEWAY_200] [MASK_200]
interface BVI 300
vrf BLUE
ipv4 address [GATEWAY_300] [MASK_300]
interface ServiceApp1
vrf NAT_IN
ipv4 address 10.0.2.1 255.255.255.252
service cgn CGN service-type nat44
interface ServiceApp2
vrf BLUE
ipv4 address 10.0.2.2 255.255.255.252
interface ServiceInfra1
ipv4 address 10.0.3.1 255.255.255.0
service-location 0/3/CPU0
router static
vrf NAT_IN
0.0.0.0/0 ServiceApp1
10.0.0.0/8 vrf BLUE bvI 2 <NEXT HOP>
vrf BLUE
172.16.0.0/24 ServiceApp2
router ospf METRO
vrf BLUE
router-id [ROUTER_ID]
redistribute bgp 65500 metric 100
area 0
interface bvi 2
router ospf BLUE
vrf BLUE
router-id [ROUTER ID]
area 10
interface BVI100
interface BVI200
interface BVI200
router bgp 65500
address-family vpnv4 unicast
vrf BLUE
rd 65500:2
redistribute static
redistribute ospf BLUE
neighbor 1.1.1.2
remote-as 64512
ebgp-multihop 5
route-policy PASS in
route-policy PASS out
service cgn CGN
service-location preferred-active 0/3/CPU0
service-type nat44 nat44
portlimit 20000
inside-vrf NAT_IN
map outside-vrf BLUE address-pool 172.16.0.0/24
Thanks in advance,
Renato
50 Replies 50
Hi Renato,
SAM modules can be physically removed from the ISM card.
As it is in IN-RESET state, the "show platform summary location 0/3/CPU0" is not able to get App-side version number.
But, as I see the following msg:
"LC/0/3/CPU0:Nov 1 17:24:54.959 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 24 in APIV module APIV_SI is incompatible (reason: Not supported on the remote side) "
I'm suspecting that the install-kit is not updated properly.
You may need to follow the instructions under http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/cg_nat/configuration/guide/cgnat43cgn.html#wp1015556.
(I'm assuming Services pie is already installed and only Linux install-kit needs to be installed)
Step 1:
RP/0/RSP0/CPU0(admin)# hw-module location reload
Step 2:
RP/0/RSP0/CPU0(admin)#debug sim reload-disable location
Step 3:
(Assuming install-kit is already copied to RP)
RP/0/RSP0/CPU0(admin)# download install-image from
to
regards,
Somnath.
Hi Somnath,
Thank you for your attention. Actually, the FPDs of the new ISM were out of date so that the ISM coudn`t boot up. What I did was shutdown the fib manager process on the card and it no longer reloaded the ISM due to the version incompatibility and then I could upgrade the FPDs and reload the module.
proc mandatory OFF fib_mgr location 0/3/CPU0
proc SHUTDOWN fib_mgr location 0/3/CPU0
RP/0/RSP0/CPU0:router#admin show platform
Mon Nov  4 07:41:48.669 UTC
Node            Type                      State            Config State
0/RSP0/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/FT0/SP        FAN TRAY                  READY
0/FT1/SP        FAN TRAY                  READY
0/0/CPU0        A9K-MOD160-TR             IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/0/1           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/1/CPU0        A9K-MOD160-TR             IOS XR RUN       PWR,NSHUT,MON
0/1/0           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/1/1           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/3/CPU0        A9K-ISM-100(LCP)          IOS XR RUN       PWR,NSHUT,MON
0/3/CPU1        A9K-ISM-100(SE)           APP-READY
0/PM0/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
0/PM1/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
0/PM2/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
Thank you so much,
Renato
Hi Renato,
That's good to hear !  So, you're all set then, I would assume.
regards,
Somnath.
Hi Somnath,
I just wanna ask if you have any extra material about the SAM modules? How can I use them?
Renato Reis
Hi Renato,
SAM module is already EOLed (http://www.cisco.com/en/US/prod/collateral/routers/ps9853/end_of_life_notice_c51-721386.html).
You do not need those for running CGv6 application - those are not used by CGv6 application software.
Details about how to handle / OIR SAM module are available at http://www.cisco.com/en/US/docs/routers/asr9000/hardware/ism_line_card/installation/guide/ismiginstalling.html#wp865031.
regards,
Somnath.
Renato Reis
Hi Somnath,
Let's see if you can help with this new scenario. I want to extend this NAT configuration to a new site (BO1), but instead of using this entire setup with ASR9K, etc, I just want to use ASR9000v module and have this AS9K + ISM as the host. The first problem I see in this scenario is that I have the same 10.0.0.0/8 network in both sites, network which will access the same resources as the devices in the 10.0.0.0/8 in the main site.
1) Do you think if I create a new inside VRF [NAT_IN1] would address this issue?
2) Can I use the same outside VRF?
Here is the configurations.
!! IOS XR Configuration 4.3.1
vrf NAT_IN
  import route-target
   65500:2
   65500:3
  export route-target
   65500:3
vrf RED
  import route-target
   65500:1
  export route-target
   65500:1
vrf NAT_OUT
  import route-target
   65500:4
  export route-target
   65500:4
vrf SATELLITE
vrf BLUE
  import route-target
   65500:2
  export route-target
   65500:2
ipv4 access-list ABF
5 permit ospf any any
10 permit ipv4 any 10.200.0.0 0.0.255.255 nexthop1 vrf NAT_IN ipv4 10.0.2.2
20 permit icmp any any
interface Bundle-Ether3
description Uplink (BE3 - VRF NAT_IN) - VLAN 20
vrf NAT_IN
ipv4 address 1.1.1.1 255.255.255.0
ipv4 access-group ABF ingress
interface Bundle-Ether22
description LOOPBACK CABLE NAT_OUT
vrf NAT_OUT
ipv4 address 10.0.1.1 255.255.255.0
interface Bundle-Ether23
description LOOPBACK CABLE BLUE
vrf BLUE
ipv4 address 10.0.1.2 255.255.255.0
interface 6
description Uplink  (BE6 - Global) - VLAN 20,51,80-82
interface 6.2
ipv4 address 1.1.1.2 255.255.255.0
interface 6.51 l2transport
description EFP - BE6 - VLAN 51
encapsulation dot1q 51
interface 6.80 l2transport
description EFP - BE6 - VLAN 80
encapsulation dot1q 80
interface 6.81 l2transport
description EFP - BE6 - VLAN 81
encapsulation dot1q 81
interface 6.82 l2transport
description EFP - BE6 - VLAN 82
encapsulation dot1q 82
interface Bundle-Ether100
description Bundle to Satellite 100
vrf SATELLITE
ipv4 point-to-point
ipv4 unnumbered Loopback0
nv
  satellite-fabric-link satellite 100
   remote-ports GigabitEthernet 0/0/0-43
interface Bundle-Ether200
description Bundle to Satellite 200
vrf SATELLITE
ipv4 point-to-point
nv
  satellite-fabric-link satellite 200
interface Bundle-Ether300
description Bundle to Satellite 300
vrf SATELLITE
ipv4 point-to-point
nv
  satellite-fabric-link satellite 300
   remote-ports GigabitEthernet 0/0/0-35
interface Loopback0
description MGMT SATELLITE
vrf SATELLITE
ipv4 address 10.0.0.254 255.255.255.0
interface tunnel-ip31101
description BLUE-TUNNEL01
vrf BLUE
ipv4 address 10.200.253.90 255.255.255.252
tunnel source 6.2
tunnel destination 13.13.13.13
interface tunnel-ip31102
description BLUE-TUNNEL02
vrf BLUE
ipv4 address 10.200.253.94 255.255.255.252
tunnel source 6.2
tunnel destination 14.14.14.14
interface tunnel-ip31103
description RED-TUNNEL03
vrf RED
tunnel source 6.2
interface tunnel-ip31104
description RED-TUNNEL04
vrf RED
tunnel source 6.2
interface TenGigE0/0/0/0
description LINK TO SATELLITE 100
bundle id 100 mode on
interface TenGigE0/0/0/1
interface TenGigE0/0/0/2
description LINK TO SATELLITE 200
bundle id 200 mode on
interface TenGigE0/0/0/3
interface TenGigE0/0/0/4
description LINK TO SATELLITE 300
vrf SATELLITE
ipv4 point-to-point
nv
   remote-ports GigabitEthernet 0/0/36-43
interface TenGigE0/0/0/5
bundle id 300 mode on
interface TenGigE0/0/0/16
description UPLINK  (BE6 - GLOBAL) - VLAN 20,51,80-82
bundle id 6 mode active
interface TenGigE0/1/0/16
interface TenGigE0/0/0/17
description UPLINK  (BE3 - VRF NAT_IN) - VLAN 20
bundle id 3 mode active
interface TenGigE0/1/0/17
interface TenGigE0/0/0/22
description LOOPBACK CABLE TE0/1/0/22
bundle id 22 mode on
interface TenGigE0/0/0/23
description LOOPBACK CABLE TE0/1/0/23
interface TenGigE0/1/0/0
interface TenGigE0/1/0/2
interface TenGigE0/1/0/3
interface TenGigE0/1/0/4
interface TenGigE0/1/0/5
interface TenGigE0/1/0/22
description LOOPBACK CABLE TE0/0/0/22
bundle id 23 mode on
interface TenGigE0/1/0/23
description LOOPBACK CABLE TE0/0/0/23
interface BVI30
vrf RED
ipv4 address 10.200.25.193 255.255.255.192
interface BVI31
vrf BLUE
ipv4 address 10.200.1.1 255.255.255.248
interface BVI32
vrf BLUE
ipv4 address 10.200.25.129 255.255.255.224
interface BVI33
vrf BLUE
ipv4 address 10.200.25.1 255.255.255.128
interface BVI36
vrf BLUE
ipv4 address 10.200.237.145 255.255.255.240
interface BVI51
vrf RED
ipv4 address 192.168.7.12 255.255.255.0
interface BVI80
vrf RED
ipv4 address 10.200.26.169 255.255.255.224
interface BVI81
vrf BLUE
ipv4 address 10.200.25.164 255.255.255.240
interface BVI82
vrf BLUE
ipv4 address 10.200.25.180 255.255.255.240
description NAT_IN
vrf NAT_IN
description NAT_OUT
vrf NAT_OUT
ipv4 address 10.0.2.5 255.255.255.252
description ISM
prefix-set PS_ROUTES
  10.200.0.8,
  10.200.5.40/29,
  10.200.1.0/29,
  10.200.5.32/29,
  10.200.0.144/28,
  10.200.106.0/28,
  10.200.106.16/28
end-set
prefix-set PS_BGP_BLUE_OUT
  10.200.24.192/26,
  10.200.5.40/29,
  10.200.240.0/25,
  10.200.1.0/29,
  10.200.25.128/27,
  10.200.25.0/25,
  10.200.5.32/29,
  10.200.26.0/25,
  10.200.0.144/28,
  10.200.27.128/27,
  10.200.27.0/25,
  10.200.106.0/28,
  10.200.106.128/25,
  10.200.106.16/28,
  10.200.107.128/25
end-set
route-policy RP_DENY_ALL
  drop
end-policy
route-policy RP_PASS_ALL
  pass
end-policy
route-policy RP_BGP_BLUE_OUT
  if destination in PS_BGP_BLUE_OUT then
    pass
  endif
end-policy
route-policy RP_PASS_ROUTES
  if destination in PS_ROUTES then
    pass
  endif
end-policy
router static
  0.0.0.0/0 1.1.1.20
vrf NAT_IN
vrf RED
vrf NAT_OUT
   0.0.0.0/0 10.0.1.2
   10.200.24.192/26 ServiceApp2
vrf BLUE
   10.200.24.192/26 10.0.1.1
router ospf
log adjacency changes
vrf NAT_IN
  router-id 1.1.1.1
  disable-dn-bit-check
  redistribute bgp 65500 metric 5 metric-type 2 route-policy RP_PASS_ROUTES
  area 7
router ospf RED
vrf RED
  router-id 10.200.26.169
  redistribute bgp 65500 metric 10 metric-type 2
  area 11
   interface BVI30
   interface BVI80
router ospf BLUE
vrf BLUE
  router-id 10.200.25.164
  redistribute static
  area 0
   interface BVI81
   interface BVI82
  area 2
   interface BVI31
   interface BVI32
   interface BVI33
   interface BVI36
router bgp 65500
vrf NAT_IN
  rd 65500:3
  bgp router-id 1.1.1.1
   route-target download
vrf RED
  rd 65500:1
  bgp router-id 10.200.253.90
   network 10.200.25.192/26
   network 10.200.26.128/27
   network 10.200.26.192/27
   network 10.200.27.192/26
   network 10.200.104.128/27
   network 10.200.104.160/27
  neighbor 10.200.253.89
   remote-as 64512
   ebgp-multihop 5
   update-source tunnel-ip31103
    route-policy RP_PASS_ALL in
    route-policy RP_PASS_ALL out
    soft-reconfiguration inbound
  neighbor 10.200.253.93
   remote-as 64512
   ebgp-multihop 5
   update-source tunnel-ip31104
vrf BLUE
  rd 65500:2
   network 10.200.0.144/28
   network 10.200.1.0/29
   network 10.200.5.32/29
   network 10.200.5.40/29
   network 10.200.24.192/26
   network 10.200.25.0/25
   network 10.200.25.128/27
   network 10.200.26.0/25
   network 10.200.27.0/25
   network 10.200.27.128/27
   network 10.200.106.0/28
   network 10.200.106.16/28
   network 10.200.106.128/25
   network 10.200.107.128/25
   network 10.200.240.0/25
   remote-as 64512
   ebgp-multihop 5
   update-source tunnel-ip31101
    route-policy RP_BGP_BLUE_OUT out
   remote-as 64512
   ebgp-multihop 5
   update-source tunnel-ip31102
l2vpn
load-balancing flow src-dst-ip
bridge group VLAN30
  bridge-domain VLAN30
   routed interface BVI30
bridge group VLAN31
  bridge-domain VLAN31
   routed interface BVI31
bridge group VLAN32
  bridge-domain VLAN32
   routed interface BVI32
bridge group VLAN33
  bridge-domain VLAN33
   routed interface BVI33
bridge group VLAN36
  bridge-domain VLAN36
   routed interface BVI36
bridge group VLAN51
  bridge-domain VLAN51
   routed interface BVI51
bridge group VLAN80
  bridge-domain VLAN80
   interface 6.80
   routed interface BVI80
bridge group VLAN81
  bridge-domain VLAN81
   interface 6.81
   routed interface BVI81
bridge group VLAN82
  bridge-domain VLAN82
   interface 6.82
   routed interface BVI82
nv
satellite 100
  type asr9000v
  ipv4 address 10.0.0.1
satellite 200
  type asr9000v
satellite 300
  type asr9000v
  ipv4 address 10.0.0.3
service cgn CGN
  portlimit 20000
  inside-vrf NAT_IN
   map outside-vrf NAT_OUT address-pool 10.200.24.192/26
Thanks in advance,
Renato
