Key differences between ONS-CFP2-WDM vs ONS-C2-WDM
PK99
Can someone shed some light on this?  I cannot find anything on Cisco's site on the ONS-C2-WDM-DE-1HL.
I know they will both function on the A9K-MPA-2X100GE (6.5 and up) - we run 6.7.1
I'd like to find some technical data/specs but can't find any.
Thanks!
smilstea
According to this there isn't a difference in the CFP2 or C2:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj85696/?rfs=iqvred
The main difference is whether is a D or DE/DET model and if it supports TOF:
https://www.cisco.com/c/en/us/products/collateral/routers/network-convergence-system-5500-series/datasheet-c78-741079.html
Here is another bug that describes the optic you have a question on, it only takes OTN, not LAN mode:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp23931/?rfs=iqvred
Sam
balaji.bandi
Thanks I was aware of this link and read it thoroughly but didn't quite find what I was looking for.  The CFP2 in question is a ONS-C2-WDM-DE-1HL, the link only shows "D" and "DET" and it's a bit confusing which model the "DE" version is.
smilstea
Sam
Thank you Sam!  As always you always come through.
