Bookmark
Subscribe
1865
L2 comunication between ASR Routers
Nikolas2008
I realy need some help to understand an to make the configuration for trunk links and vlan access port on routers Cisco ASR 9001 and for ASR 902.
The thing is that I need to connect costumer devices on the ASR 902 tagged with vlans and connect this traffic through a trunk link to a ASR 9001 which have the connection to the Service provider devices. All traffic es L2 there is no IPs.
Hi Nicolas, concept is fine, but I am missing the BD or XC configuration there.
One other thing to ntoe is that since you are popping the tag on the G0/0/0/18 side, you probably want to do that also on the Gig 0/0/0/6 side.
If you connect both EFP's together in an xcon like this:
l2vpn
xconnect group MYCONS
p2p first
int g 0/0/0/18.<x>
int g 0/0/0/6.<x>
for each EFP then you like them together, and what will happen is that ingress we pop the tag say 451 from GigabitEthernet0/0/0/18.451 and xcon that to GigabitEthernet0/0/0/6.451 and vbecause of the symmetric operation we push 100/451 on to the packet.
in reverse, if 100/451 comes in, we can pop that and xcon it to the g18 and apply 451 vlan dot1q single header only and you'd be good to go!!
BD when you need more then 2 endpoints.
XCON when you only need to connect 2 interfaces together (whether it be EFP, PW etc).
cheers!
xander
6 Replies 6
Peter L
yeah XR due to the EVC model has no concept of "trunks" per-se, so you need to define EFP's or ether flow points aka l2transport subinterfaces for those vlans that you want to transport.
check the dekc from orland2013 from this query:
https://www.ciscolive.com/online/connect/search.ww#loadSearch-searchPhrase=2904&searchType=session&tc=0&sortBy=&p=&i%2810017%29=19409&i%2810017%29=16627&i%2810017%29=14187
it has some IOS ot XR comparison configurations that will probably help.
xander
Thanks for the reply.
I already did that l2 subinterface configuration, but I cant complete understand the rewrite command and how it works.
If the connected devices are already sending traffic with 802.1q tags, do I need to remove those tags in order to send them throught the l2 subinterfaces ?
ah I see, I think I have a nice piece for you here.
it details out the precise func of that command.
if you have BVI's in your bridge domain you must pop the tags.
if you are doing l2 transparent services and no vlan translations or anything you *could* leave the tag as is, or there is no need to pop.
In the other hand, if the vlan is not service delimiting, you might as well pop it (to save some bytes) and push them at the remote end again. the rewrite operation doesnt cost you performance or anything.
cheers!
xander
Thanks Alexander for your help. One more thing, can you tell if the configuration is correct for this scenario?,
This is the topology.
The configuration apply is this:
ASR920
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
 service instance trunk 1 ethernet
  encapsulation dot1q 51-52,76,99,150,451,1715,1717
  bridge-domain from-encapsulation
interface GigabitEthernet0/0/5
 no ip address
 media-type auto-select
 negotiation auto
 service instance 51 ethernet
  rewrite ingress tag pop 1 symmetric
  bridge-domain 51
 service instance 52 ethernet
  encapsulation dot1q 52
  bridge-domain 52
ASR9001
interface GigabitEthernet0/0/0/6
 description ##IFACE-to-ALU-QinQ##
interface GigabitEthernet0/0/0/6.76 l2transport
 encapsulation dot1q 100 second-dot1q 76
interface GigabitEthernet0/0/0/6.150 l2transport
 encapsulation dot1q 100 second-dot1q 150
interface GigabitEthernet0/0/0/6.451 l2transport
 encapsulation dot1q 100 second-dot1q 451
interface GigabitEthernet0/0/0/6.1715 l2transport
 encapsulation dot1q 200 second-dot1q 1715
interface GigabitEthernet0/0/0/6.1716 l2transport
 encapsulation dot1q 200 second-dot1q 1716
interface GigabitEthernet0/0/0/6.1717 l2transport
 encapsulation dot1q 200 second-dot1q 1717
interface GigabitEthernet0/0/0/10
 description ##IFACE-to-ALU 7450IMS##
interface GigabitEthernet0/0/0/10.51 l2transport
interface GigabitEthernet0/0/0/10.52 l2transport
interface GigabitEthernet0/0/0/18
 description ##IFACE-TRUNK-to-ASR902##
interface GigabitEthernet0/0/0/18.1 l2transport
 encapsulation untagged
interface GigabitEthernet0/0/0/18.51 l2transport
interface GigabitEthernet0/0/0/18.52 l2transport
interface GigabitEthernet0/0/0/18.76 l2transport
 encapsulation dot1q 76
interface GigabitEthernet0/0/0/18.99 l2transport
 encapsulation dot1q 99
interface GigabitEthernet0/0/0/18.150 l2transport
 encapsulation dot1q 150
interface GigabitEthernet0/0/0/18.451 l2transport
 encapsulation dot1q 451
interface GigabitEthernet0/0/0/18.1715 l2transport
 encapsulation dot1q 1715
interface GigabitEthernet0/0/0/18.1716 l2transport
 encapsulation dot1q 1716
interface GigabitEthernet0/0/0/18.1717 l2transport
 encapsulation dot1q 1717
Thanks again.
Best regards
l2vpn
p2p first
int g 0/0/0/18.<x>
int g 0/0/0/6.<x>
cheers!
xander
