Loopback for pce peer source
coolexer1987
Hello!
Software IOS-XR 6.0.1
Can I use loopback address for comand Loopback for "mpls traffic-eng pce peer source ipv4" ?
When I set the ip address from loopback the packets stop to send.
It's a strange behavior to use only physical interface because:
1) Loopback provides redundancy
2) subnets for physical ptp interfaces are not available for management very often.
Thanks in advance
here is a config snippet that our dev test used for verification:
pce
  peer source ipv4 192.168.168.168
  deadtimer 120
  peer ipv4 192.168.1.1
  peer ipv4 192.168.178.178
  logging events peer-status
  keepalive 60
  stateful-client
   instantiation
   report
   fast-repair
  reoptimize 240
  tolerance keepalive 25
ipv4 unnumbered mpls traffic-eng Loopback0
interface Loopback0
ipv4 address 192.168.168.168 255.255.255.2
maybe the bold line is missing in yours?
xander
xthuijs
hi coolexer,
technically this should work, it makes sense for it to be a loopback addr as you mention.
the addr is used as a source for the tcp connections hence makes sense to be redundantly available.
there may be a stipulation with lpts (hole piercing) but it sounds like that no packet is sent at all when that source is selected?
even if not supported, documentation should reflect taht restriction which is not there either.
would recommend to file a tac case with the show tech mpls traffic-eng to have this evaluated and corrected either with documentation or sw.
cheers
xander
Hello xthuijs!
Yes, technically it should work because it usual function.
But when I change ip address from physical interface to loopback It doesn't send pcep packets at all...
Of cource I can ping loopback from PCE server.
pce
  deadtimer 120
  keepalive 60
  stateful-client
   instantiation
   report
   fast-repair
  reoptimize 240
interface Loopback0
xander
I checked with the TE dev team and indeed this is supported and should work.
we need to investigate this more why it doesnt.
it might be best to look at XR602 or 61<latest> however instead of 601.
the tech mpls te would help as well as some debugs to see how it gets initiated and if the packets are generated properly.
xander
