MPLS TRUNK CONFIGURATION on TWO EDGE
saul.reyes
Actually we have a network operate VRF on two EDGE (ASR9000) the diagram is this:
we try to configurate a MPLS conection between ASR (PE-1) and ASR (PE-2) try to use MPLS LDP and use a VRF OAM between this devices but the comunication is not possible
MPLS LDP is the option? or L2VPN or EoMPLS for this connection?
the actually configuration is:
ASR-2
mpls ldp
router-id 172.16.14.1
discovery hello holdtime 30
discovery hello interval 10
graceful-restart
explicit-null
interface Bundle-Ether100
ASR-1
mpls ldp
router-id 172.16.14.2
graceful-restart
explicit-null
but the VRF OAM only configurated between PE-1 and PE-2 is not neighbord
We don´t know if we are using the correct concept to connect the devices, can help us
thanks
Best Regards
Hi Saul,
The reason you can not ping from asr9k-1 to asr9k-2 is that you do not run mpls vpn (bgp vpnv4) between the two. What do you need that vrf for? If it just to provide connectivity between loopback interfaces for vrf OAM on asr9k-1 and 2,  I do not really see the point.
Harold Ritter
Hi Saul,
I am not sure what you are trying to achieve. You want to run mpls vpn between the two asr9k to extend a VRF called OAM, right? If so, ldp is definitely one way to do it. The reason why the ldp session does not come up might be that you do not have loopback address reachability from one asr to the other. Do you run and IGP between the two asr?
Harold, thanks for your comments
we are making change for your comments and the final diagrame is:
on ASR9K - PE-1 we have configurated VRF, IGP and Conectivity for BUNDLE-Ethe 100 conectivity
ASR9K (PE-1):
vrf OAM
address-family ipv4 unicast
  import route-policy pass-all
  import route-target
   64518:64518
  export route-policy pass-all
  export route-target
   64518:64518
ipv4 address 172.16.14.1 255.255.255.252
interface Loopback10
vrf OAM
ipv4 address 172.16.162.1 255.255.255.255
router ospf 100
mpls ldp sync
mpls ldp auto-config
area 0
mpls ldp
ASR9K (PE-2):
vrf OAM
  import route-target
   64518:64518
  export route-target
   64518:64518
ipv4 address 172.16.14.2 255.255.255.252
vrf OAM
ipv4 address 172.16.162.2 255.255.255.255
router ospf 100
mpls ldp sync
area 0
mpls ldp
when we verifying  the MPLS neighbor is UP
RP/0/RSP0/CPU0:ED_MEX_1#sho mpls ldp neighbor
Wed May 22 18:29:03.496 UTC
Peer LDP Identifier: 172.16.14.2:0
  TCP connection: 172.16.14.2:39527 - 172.16.14.1:646
  Graceful Restart: No
  Session Holdtime: 180 sec
  State: Oper; Msgs sent/rcvd: 25/25; Downstream-Unsolicited
  Up time: 00:18:46
  LDP Discovery Sources:
    Bundle-Ether100
  Addresses bound to this peer:
    172.16.14.2
RP/0/RSP0/CPU0:ED_MEX_2#sho mpls ldp neighbor
Wed May 22 16:24:53.223 UTC
Peer LDP Identifier: 172.16.14.1:0
  TCP connection: 172.16.14.1:646 - 172.16.14.2:39527
  State: Oper; Msgs sent/rcvd: 26/26; Downstream-Unsolicited
  Up time: 00:19:19
    Bundle-Ether100
    172.16.14.1
on OSPF 100 the neighbor is UP
RP/0/RSP0/CPU0:ED_MEX_2#sho ospf neighbor
Wed May 22 16:26:15.169 UTC
* Indicates MADJ interface
Neighbors for OSPF 100
Neighbor ID     Pri   State           Dead Time   Address         Interface
172.16.14.1     1     FULL/BDR        00:00:31    172.16.14.1     Bundle-Ether100
    Neighbor is up for 00:54:34
Total neighbor count: 1
RP/0/RSP0/CPU0:ED_MEX_1#sho ospf neighbor
Wed May 22 18:31:18.614 UTC
172.16.14.2     1     FULL/DR         00:00:36    172.16.14.2     Bundle-Ether100
    Neighbor is up for 00:54:59
but when try to send a PING from Loopback 10 from ASR 1 to ASR 2 ocurre this one and viceverse
RP/0/RSP0/CPU0:ED_MEX_1#ping vrf OAM 172.16.162.1
Wed May 22 18:32:54.046 UTC
Sending 5, 100-byte ICMP Echos to 172.16.162.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
RP/0/RSP0/CPU0:ED_MEX_1#ping vrf OAM 172.16.162.2
Wed May 22 18:32:57.794 UTC
Sending 5, 100-byte ICMP Echos to 172.16.162.2, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
the routing table for OAM on ASR-1  is:
RP/0/RSP0/CPU0:ED_MEX_1#sho route vrf OAM
Wed May 22 18:33:59.485 UTC
Codes: C - connected, S - static, R - RIP, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
       U - per-user static route, o - ODR, L - local, G  - DAGR
       A - access/subscriber, - FRR Backup path
Gateway of last resort is not set
L    172.16.162.1/32 is directly connected, 00:34:13, Loopback10
for ASR-2
RP/0/RSP0/CPU0:ED_MEX_2#sho route vrf OAM
Wed May 22 16:30:23.400 UTC
L    172.16.162.2/32 is directly connected, 00:34:47, Loopback10
i don´t know if need something on OSPF
Best Regards
Hi Saul,
Hi Harold
thanks for your answer, the loopbacks are for management and traffic for traps of SNMP, and would you like to be this traffic isolated for this one and only connected for this VRF, but with your observations think that we make things wrong with this.
we try to enable the Vpnv4 on BGP for the neighboar and evaluating the concept to do this.
thanks so much Harold
