Mixed Layer 2 & Layer 3 Interface
Hi Guys,
We are working on a design for 2 data centres, we are using the ASR9K's as the PE's for both DC's (there will be 2 at each DC but they will be clustered so will logically be one), the 2 DC's are connected with 2 circuits for resiliency and running MPLS.
We will have a 'service interface' on the 9k at DC1 that will be in a public /24 and there will be firewalls for different customers that have external interfaces in that network that will use the 9k's IP address as their default GW.
Let's say the VLAN is VLAN 19
Let's say the subnet is 19.1.1.0/24
DC1 ASR 9K: 19.1.1.1
DC2 ASR 9K: 19.1.1.2
So this network and all the customers on it exist in DC1, their firewalls are using 19.1.1.1 as their GW.
If a handful of customers (or just 1) need to DR and move their Firewall (and the VM's behind it) to DC2 then we will now have some of that /24 existing at DC2, inherently we will need a subinterface (service interface) on that 9k which is 19.1.1.2 so I can change the GW for the migrated firewalls to 19.1.1.2, this can be a manual thing.
My concern is that now VLAN 19 exists at both DC's but hasn't been stretched at layer 2, is there a way that I can configure the layer 3 stuff (IP address) and a xconnect/pseudo wire on the same interface so that when traffic is destined for the something on that subnet, lets say 19.1.1.100 the ASR at DC1 will ARP out of its local interface AND over the pseudo wire to reach the firewalls at DC2.
Hope this makes sense, if not I can upload a diagram on request, or please just ask any questions for me to try and clarify
Thank you all
xthuijs
yeah diagram may help indeed, but as an attempt for a response: how about you create the L3 endpoints as BVI
a bridge domain for your vlans and extend/conenct the bridge domains with a PW.
cheers!
xander
I haveattached a diagram but judging from your answer I think you get what I am trying to do.
I am not familiar with this configuration so do you have a link to a doc or any config examples?
I am guessing you put the bridge group on the interface g0/0/1.19 + the xconnect, and then put the ip address on the BVI interface???
Like I said any docs on this would be brilliant, thanks for your reply.
that is pretty straight forward, thanks for the visual!
here are some config examples:
https://supportforums.cisco.com/docs/DOC-15556
and this one: https://supportforums.cisco.com/docs/DOC-22848
trick is you move your gig interface that currently has that ip address and convert it to:
int g0/0/0/10.20 l2trans
encap dot1q 20
rewrite ingress tag pop 1 sym !important!!
interface bvi 20
ipv4 addr (your 19.1.1.1)
l2vpn
bridge group something
bridge domain vlan20
interface g0/0/0/10.20
routed interface bvi 20
vfi X
neighor
you can also pull in a vlan/attachment circuit directly to your peer if you dont want to enable mpls/ldp
and use a pw. either way works.
regards
xander
